Tool Talk Discussion Forum
Sandblaster
LumbrJakMan
12-14-2005 13:55:38
Hello. I have my first Tractor restoration ongoing. I got a price on some Sandblasting and its Obvious The Good Lord wants me to Buy one and have my own . I was convinced when I cleaned my shop and found an empty area just big enough to store one . I would like to know what you guys have Bought and are Happy with , and even more important what you have got and Been UNHAPPY with !Any tips are well appreciated .
Thanks in advance all , you always help me !!
fixerupper
12-15-2005 20:19:03
 Re: Sandblaster in reply to LumbrJakMan, 12-14-2005 13:55:38
If you have enough air capacity, go ahead and get a sandblaster, it's a good restoration tool and will clean out all of the cracks and crevices. Just realize that you will have to remove the part from the tractor first because like Joe said you will get sand into places you couldn't imagine possible if you blow sand on the tractor. Sandblasting works great for wheel rims, wheel cstings, seats, etc. if they are removed from the tractor first. Anymore, I sand the sheet metal with a DA and wire brush any part of the tractor that contains bearings or oil reservoirs then I hit the rest of the parts with the sandblaster. I just can't get excited about introducing water to steel while denuding it of paint. Jim
Shovelman
12-15-2005 14:50:31
You did not mention if you are considering a cabinet or pot type blaster.
I have owned a TiP pressure pot blaster for years and have had good luck with it. Have used different types of media and found the fine grade of Black Beauty (black slag) cuts well, flows well thru the blaster and doesn't work its way into joints, etc. the way white silica sand does.
A couple of hints: buy a good hood, wear long leather gloves, coveralls, ear plugs and always wear a respirator due to the lead in many of the old paints. Use care when blasting flat sheet metal as you can distort it.
Start with a clean, dry tractor (steam clean or pressure wash), tape off all glass, chrome and gauges, wrap rags around the areas you want to protect and be very sure to plug the intake and exhaust with rags and seal with duct tape. Stay away from sensitive areas such as the radiator, distributor cap, U-joints, glass, etc..
When finished, blow it off well with compressed air and then prime it with an etching (bare metal) primer that is compatible with the top coat(s) you plan to use.
We also have a small cabinet blaster that we use for smaller work. Black Beauty works good here as well.
As you probably know, blasters require a lot of air, so be sure your compressor is big enough for what you purchase. Good luck,
Scott
DJM75
12-15-2005 04:41:38
may I make a suggestion I know it's a lot of work but how about some scrapers,wire brushes and a pressure washer with degreaser.
Joe Evans
12-14-2005 19:21:47
DO NOT SANDBLAST A TRACTOR! DON'T EVEN THINK, DREAM, CONTEMPLATE, MUSE, OR PLOT ABOUT DOING IT!
Yes, I was shouting. If you sandblast, sand will get into areas you never dreamed existed and quickly ruin bearings seals and shafts. I don't care how careful you think you are, you'll regret every waking moment of ever doing it.
The company I worked for sandblasted two forklifts in order to get them looking nice to add to our rigging fleet. Total disaster. Those machines we were counting on leaked oil from everywhere, wheel bearings went south, and brake drums with the shoes took a hike, too.
Sandblasting is very effective. Agreed on that, but it should be used on parts that can be totally taken apart and cleaned.
mjbrown
12-14-2005 15:38:13
I've been happier with wet blasting than with dry. $60 will buy an attachment for a high pressure washer that adds sand to the spray.
I got mine a Northern Tool.
Chuck430C
12-15-2005 12:52:53
 Re: Sandblaster in reply to mjbrown, 12-14-2005 15:38:13
MJ,
Please provide the details on the device that allows sand to be sprayed in a pressure where. I cannot locate it at Northern Tool.
LumbrJakMan
12-14-2005 17:42:50
I just searched Northern Tool and couldnt see the adaptor you suggested ???
Jay87T
12-15-2005 09:40:38
 Re: Sandblaster in reply to LumbrJakMan, 12-14-2005 17:42:50
how much PSI do you need with your pressure washer to work effectively with this sandblaster attachment? My pressure washer is 1600psi.
SAD
12-14-2005 15:15:14
PH#218-897-5382 Hello Sir. I have had your delema,I also Made my own sandblaster.I charge $70 hr and can sand your tractor in about 6-7 hrs completly paint and rust free. After you remove all guages and glass sediment bowl.Take off all tin you want to paint underneath and the radiator. Now for the compressor,get something in the range of 150 CFM @150psi MIN.output. Make sure it is a rotary screw,Causes less problems in the long run.Buy and aftercooler At least 250 cfm range .Get a couple moisture traps at least 2-5 gallons each.And last, most all sand blasters will work. Make sure it is a prussurized tank. around 100 to 250 lbs of max blasting sand . Ran out of room.
NEsota
12-14-2005 14:27:42
My experience with sandblasting is zero but a friend used it on his small Farmall and got sand in the bearings, which he found objectionable. A lot of experience on this forum and you will get some good advice. My take is that sand blasting should be keep away from anything with seals or moving parts. I believe in the Hippocratic oath; �First do no harm�.
