Tool Talk Discussion Forum
drill bits
hay
12-14-2005 13:22:15
what do you all do about dull drill bits? do you try to sharpen them or buy new ones. i have a drill bit sharpener or two and seems like the darn things take forever to set up and sharpen bits. and the bits NEVER cut like a factory new ones because the natural curve of the bit is taken off and is left flat. i tried other bit sharpeners and they don't do much better and the bits will drill fairly good for one or two times and then dull again quickly. i'm only drilling common steel, nothing hardened. buying new bits can get expensive. what about the nitride coated bits, do they last longer? are they really worth the extra cost? need some input on this perplexing problem.
old art
12-15-2005 08:30:09
 Re: drill bits in reply to hay, 12-14-2005 13:22:15
i have a drill doctor didn't like it when igot it. then i re read the directions fowled them very close found what i did wrong now i like it much better whenyou do a broken bit reset in the holder after you have got it shaped upalmost done helped me a lot . art
chvet73
12-15-2005 07:25:17
Get a Drill Doctor. Easy to use and works great.
Nolan
12-15-2005 04:49:38
I sharpen and reuse. Used to do it by hand, with mixed results. Now use the DrillDoctor with very good and consistent results.
Have used other drill bit sharpeners over the years, didn't like any of them until the drill doctor. OK, we did have one big commercial unit for the 1"+ drill bits that worked great, but it wasn't for small bits and was real expensive.
mechman
12-14-2005 21:17:00
dressing them on a bench grinder is all ive ever needed to do.
john d
12-14-2005 19:40:47
Drill Doctor does okay. With practice (after somebody shows you how) you can do a good job by hand on drills over 1/4" or so.
HSS split-point with a 135-degree end on them is your best bet. Buy drills made in the USA, and you'll get lots better life out of them than the ones made in China. If you're drilling mild steel, keep the speed down, put some pressure on the drill, and add some oil. Hard to hurt a drill by running it too slowly, but too much speed dulls them in a hurry.
The coated drills probably won't help you much.
hay
12-15-2005 04:58:42
 Re: drill bits in reply to john d, 12-14-2005 19:40:47
i have been using a small drill press for most of my smaller (up to 3/8") drilling. i have the press running about 900 rpm. but can go as low as 450 rpm. would slowing down to 450 rpm save my drill bits from dulling so quickly? also where are the 135 deg drill bits available? i have not seen them in the local hardware store. maybe home depot or lowe's ? i'm about at my wits end with constantly buying new bits and trying to sharpen the old ones. seems like they just aren't made worth a flip anymore (like everything else).
timcasbolt
12-25-2005 17:33:05
 Re: drill bits in reply to hay, 12-15-2005 04:58:42
135* drill bits are around, but not that common in hardware stores. MSC and Enco have them. They are for tough cutting situations like stainless steel. Often with cobalt and a split point.
Bill WI
12-15-2005 11:52:12
use the 450 for 3/8 to 1/4. For under 1/4 step it up and use the 900 just 1/8 down. The amount of presure you use (feed) makes a difference too. A small bit will break at slow speed. Also look for high speed steel bits. Heat kills carbon steel bits. At 400 degrees the edge starts breaking down. In otherwords if you get a blue chip on these, the edge is going and as it dulls it just gets hotter. High speed steel bits are marked HSS on the shank with the size and brand.
hay
12-15-2005 12:05:30
 Re: drill bits in reply to Bill WI , 12-15-2005 11:52:12
i tried slowing the speed to 250 rpm and drilling 1/2" and it worked ok. then i tried 450 rpm with 1/2" bit and it still did good. the slower speeds definatly is the way to go. a good sharp drill bit is essential. thanx for the information.
MPK
12-14-2005 17:31:57
I sharpened by hand for many years till I finally got a Drill Dr, easy to use and does a good job. I would never go back.
Ryan - WI
12-14-2005 13:28:51
I use a Drill Doctor I have at school. Quick setup and not a bad edge if done correctly.
Midwest redneck
12-14-2005 13:24:21
I sharpen my bits on a belt sander, works good. Nitride coated bits dont make much of a diff. to me, I buy the HSS bits the M42 cobalt work the best next to carbide
