Tool Talk Discussion Forum
Torch Purchase
Warren in Wisc.
12-14-2005 12:35:13
My wife has agreed to get me a torch for Christmas. She has her eye on the "portable torch" as found in Home Depot. These portable systems are all self contained in a handy dandy carry unit. Some things I am concerned about these units are;
Where do I get the tanks refilled? They are the small 20 cu ft ones.
Do these things last for more than a few minutes of cutting?
Are there any quality/safety issues?
I had my eyes on a regular cutting torch kit made by Smith which comes with everything but the tanks. The price is about the same as the portable unit from Home Depot, but I will have to buy the larger tanks for about $300.
What do you think? Go for the big one?
JD9295
12-17-2005 04:53:00
 Re: Torch Purchase in reply to Warren in Wisc., 12-14-2005 12:35:13
But the victor torch kit and tell your air gas man you want to buy the (Q) bottles. They will be yours, no lease to deal with and you can exchange them anywhere that handles (Q) bottles, which ive found is anywhere that has oxy/acyt.
I switched mine over a few years ago when the lease on our shop bottles was VOIDED because of a business buyout. Went to another jobber and after he showed me the advantages on paper I switched my argon to Q bottles also. They are cheaper and alot lighter to throw in the truck
van robinson
12-15-2005 22:25:42
One word... VICTOR
Tim B from MA
12-15-2005 13:06:21
Warren,
At this point you are probably sorry you asked, right?
Anyhow, here is a link to northern tool, Gernico brand or some such, which I think is now owned by Victor. I can't comment on the quality since I've only seen the picture, but this set-up looks just like my Victor 100.
http://www.northerntool.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=6970&productId=9049&R=9049
barnrat
12-15-2005 05:51:35
I have a cheap set of generic victor gauges and tips I bought 5 years ago with 75 ft of hose(to go up silo if needed)and have put them trough all sorts of awful places around the dairy farm and shop. I lease from the local welding supply company an 80 cu. ft. oxygen and 40 cu. ft. acetylene. I think even after 5 years I haven't spent in leasing what new tanks would cost.
Tim from MA
12-15-2005 08:12:42
 Re: Torch Purchase in reply to barnrat, 12-15-2005 05:51:35
Re: leasing vs buying tanks. My recollection when I bought my tanks was that leasing was $90/yr vs the $300 or so to buy them.
You will just need to price out the difference with the welding shops in your area.
Stan - you are correct re; past discussions of using propane. Mark KW seems to be the authority.
kirk / ihcollector
12-15-2005 05:17:00
Warren, either torch would work. Save yourself some money and go to Farm and Fleet to get your torch. Home Depot is @ 40% more than F&F.
Stan in Oly, WA
12-14-2005 22:24:52
Hi again,
For one of the best discussions you'll ever read on the use of propane for cutting, go to the archives for this forum, click on "search by author", and look through posts by Mark Kw. Find this one: Posted by Mark Kw on May 27, 2001 at 06:12:59 from (216.37.229.149):
Stan
Tim B MA
12-14-2005 21:29:07
Ditto on all the advice to get brand name torches (I have Smith F-100 cutting and welding torch, which can be had for under $200) and the "half size" oxy and acetylene tanks. I bought mine a few years ago for about $500 for torch, tanks, and cart.
If you are only planning to use the torch for heating and cutting, not welding, you may get by with oxy and propane, so you could skip buying the acetylene tank. From many discussions on this board I understand that propane is better in many ways for cutting (if you have the appropriate tip - I think Harris make a torch just for propane and oxy cutting which some think is much better than just a tip on a oxy-acetylene torch. Oxy-propane does not get hot enough for gas welding.
Do a search of this board, there is a ton of info on cutting with propane.
Good luck.
Tim B from MA
12-15-2005 08:24:41
 Re: Torch Purchase in reply to Tim B MA, 12-14-2005 21:29:07
Correction, my torch is a Victor 100, not Smith. I have seen set ups in Northern Tool catalogs that look just like mine, but with more tips (which ain't cheap) for about $40 less than I paid. These may be the "generic victor" set up the gentleman above refered to.
I would be interested in knowing the relative quality.
MarkB_MI
12-14-2005 19:26:31
Go with the Smith torch. I have the Smith Cavalier set, which is their light-duty torch, and it's great.
One problem with the smaller tanks is that there's a limit on how fast you can draw down your acetylene before it becomes unstable. It seems like it's one-fifth of the tank capacity per hour, but someone will correct me. This rules out the use of rosebuds and large cutting tips with the portable tanks.
Stan in Oly, WA
12-14-2005 18:55:06
Hi Warren,
Here's the address of a company I've done business with online and been very happy with:
www.atlweldingsupply.com
He sells mostly oxy-acet/oxy-propane torches and equipment, but seems to be branching out to low end welders.
I'd cast my vote with those who advise you to buy good equipment the first time. I'll bet if you buy good quality torches, regulators, hoses, and decent sized tanks from a local supplier (not HD) you'll never look back and think, "I wish I'd bought cheap equipment and small tanks when I had the chance; now I'm stuck with this great stuff that does everything I need and never gives me any problems."
I've rented tanks for two years now, and feel pretty stupid as the total rental I've paid passes the price of at least one tank purchase. I haven't needed a refill on my gasses yet, but the meter just keeps on running.
Merry xmas, Stan
thejdman01
12-14-2005 15:43:15
super pricing but if you can afford a petrogen you will be amazed. petrogen wont braze though if you do that. go for ht ebig ones.
supergrumpy
12-14-2005 13:05:51
I lived with a worn out low quality torche set for too long, regulators jumped all over the scale
finally sold the works and got good quality units at local welding shop, 1/2 size tanks that won"t give you a hernia when you have to drag them outside, plus anti-backfire valves and nice long hoses
paid a bit but these guys will outlast me, any problems and the welding shop guys help me out, try that at Home Depot
you get what you pay for
my 2 cents
John Garner
12-14-2005 13:03:14
 Your Local Welding Supply House! in reply to Warren in Wisc., 12-14-2005 12:35:13
Warren --
Do yourself a favor and buy from your local welding supply house . . . and while you're at it, have them fill you in on using propane as your fuel gas rather than acetylene. Propane has many advantages.
John
Mike M
12-14-2005 12:47:12
My bigger tanks last for years with what little I use them. I could do with the small ones.I would say buy an outfit from the local welding shop that fills tanks.Compare refill costs too,smaller may cost more ?
TimV
12-14-2005 12:46:03
Warren: Unless you really need portability, I'd go with the larger set. You can always put smaller tips on a larger set, but not vice versa. Assuming these are the usual small torch sets, they're fine for heating and occasional cutting, but refills (which are commonly availible at most places that handle gas) are only a few dollars less than a tank twice their size. Also, large tips will deplete them in a hurry, particularly the acetelyne. You can only safely take about 1/7 of the acetelyne from a bottle per per hour, which doesn't make these sets idea for prolonged use.
rc in ct
12-14-2005 13:24:12
 Re: Torch Purchase in reply to TimV, 12-14-2005 12:46:03
Ditto on calling your local gas & welding supplies company. One of our local suppliers is having a end of the year speacial on a complete set made by Harris (cutting and brazing, regulators and hose) with tax its $220. Includes a #1 cutting tip and some saftey gear.
chvet73
12-15-2005 07:28:18
 Re: Torch Purchase in reply to rc in ct, 12-14-2005 13:24:12
Get the Victor 100 series setup. I have had the Smiths and Victor Journeyman. The 100 is the best setup.
Do not get the small tanks. You will be filling them every time you turn around. I have medium size and they still don't last long enough.
