Tool Talk Discussion Forum
The Ultimate Dream Shop
Randy_NE
12-14-2005 06:12:24
Well after several years of saving my pennies I am ready to build a shop where we used to have a barn. It was torn down and and the site leveled about 5 years ago.
I am looking at somewhere in the 40 x 50 range for size and am in the process of pricing metal pole buildings from various company's.
I still may stick build it if the prices come in to high, but would really like to have a shop done in a week or so instead of me taking all year to build it after work & weekends ; )
Anyway, would like any input on things to add or do while building it. I plan on heating it but not sure how yet. And I plan on using it to restore Farmall H's and keep a couple of vehicles inside.
Randy
Randy_NE
12-22-2005 11:25:40
 Re: The Ultimate Dream Shop in reply to Randy_NE, 12-14-2005 06:12:24
Well I got my first bid amount from Morton, came in at $32,000! Includes floor, one 16' overhead door, entrance door and 4 windows, Ouch! Add another $14,000 for complete interior insulation!
I guess I will have to build it myself over several months.
I think I will try and get the slab poured this spring, need some advice on using rebar or mesh or anything else for strength.
Randy
DJM75
12-15-2005 04:46:50
If you want something you can put up quick and ease and durable check out miracle truss steel building.
ricedaddy
12-15-2005 01:40:49
[email protected] just did one for me and I was well pleased
Charles (in GA)
12-14-2005 19:06:17
I would pole build only if I used genuine cresote telephone poles seet deep in the ground.
My workshop is an aircraft hangar, I live in a fly-in community/airpark. Being in Georgia, we don't have the low temps and long duration of low temps you do in Nebraska, so what I did nay not at all be applicable to your situation.
If you build a real high eave height, you have alot to heat, and out there, you gotta heat. Consider real hard, a used/waste oil heater system such as the Clean Burn, either a forced air or a boiler system for a heated floor. Solves the problem of getting rid of drained oil and hydraulic fluids, and you can always run it on fuel oil, kero, diesel, etc if you don't have enough used oil. Your neighbors will probably help out with the used oil too.
Follow the link to the first of two web pages on the construction of my hangar, might give you an idea or two. or what not to do.
Link
Cliff Neubauer
12-14-2005 15:48:50
When I build a shop it will be stick built with 18 1/2' tall walls on top of a 1' tall concrete wall. By the time you finish out and insulate a pole building I don't think the stick built will cost much more in materials and I wouldn't think there would be alot of difference in labor. The stick built building will be stronger and will last much longer than a pole building. The steel buildings are nice but most are only designed for 4-6" of insulation and in my opinion that's not nearly enough. I will go with floor heat combined with a corn burning boiler, it will cost a little more up front but in the long haul it should be very cheap to operate. I would put in two doors, one bigger door like a 20x14' and one smaller like 16x14' so you can move stuff in and out without worrying about the door being blocked. If you are going to be restoring tractors I would plan on being able to seperate an area for painting, in my shop I am going to have a bay that can be seperated by a curtain or an accordian style folding wall with an exhaust fan.
thejdman01
12-14-2005 15:40:01
put up a 70x80 shed/shop partitioned, was a "huge building for me" im looking at putting up a 60x60 soon. 2 things i wouldnt put up another building without would definitly be a wash bay of some sorts, clean off the dirt oil etc w/o dirting a bunch of rags or brake clean etc, also if you keep it in the heated part you can wash the little ladies car and keep her happy in the winter. also cleaning parts for restoring purposes esp in winter before painting sandblasting would be very good for you. another thing would HAVE to be an over head 5 ton crane. lifting engines off combines, pulling engines lifting semi duals onto my amco brake lathe its very handy to have one. you will be amazed amazed how fast a shop takes and shrinks. by the time you put in your heater, parts washer, bench, storage, bolt bins, tool box,sand blaster cabinet, grinder, drill press welder, plasma cutter torch cart possibly lathe desk etc etc you quickly realize ship gets eaten up, very quickly. i would consider a cinder block building or a metal framed building as well.
Mark - IN.
12-14-2005 10:34:09
Well, you mentioned the important thing, "up soon or now", as opposed as to when you can work it in. 40'x50' isn't real big after you stick a couple of vehicals in, for restoring stuff. You'll see, the barn will somehow shrink in front of your eyes. But, with a steel building can always take down an end wall and grow it out, then put the end wall back up. Good choice.
Can do a Google search on "pole barns" and find suppliers, often that will contract out the labor locally. When I put up my barn, the labor went for 1/2 of total cost. For instance, $10K in materials will be about $10K in labor = $20K. Here, I hear good and bad about Morton. Out in the in the fields where I know people that have Morton, I don't hear complaints, but are they calling in warranty repairs? Probably not. Mine wasn't Morton. Mine is DIY and went through an Amish crew that put it up for me. Included the concrete. A couple that I looked into had no sales/marketing near me. I'm in Indiana on the Michigan boarder, and one was out of Kokomo and wouldn't touch it, another was out of Illinois that wasn't Morton, but the sales guy could only come on a day when I was working in Illinois. I was going to go through DIY, but the Amish guy did it for me.
One thing to be careful about is start and finish dates. Get it in writing, in partial payments, with a last payment upon completion. Paid them Amish guys November 1st, had good concrete weather until mid-December, they tooled up in buggies with a foot of snow on the ground. Worked a couple of days, then celebrated Christmas on like the 19th, so got dragged out to mid-January with all of the snow. Good barn, good workers, not in a hurry though, them guys aint.
One last thing. Them doors. If you figure 12' wide, go 16'. It can be fixed, but it aint fun. Been there, done that.
Mark
RustyFarmall
12-14-2005 08:28:48
I put up a Morton several years ago, the price was roughly twice the cost of a comparable building package from Menards, which shows you what Morton charges for erecting the building, which was OK with me because I didn't have to touch a thing. As a side note, I will tell you that Morton's quality is no better than Menards, and the construction crew took about 3 1/2 MONTHS to get the job done, and then had to come back several times to correct the many mistakes they made. I will not recommend a Morton.
Ducknose Bob
12-14-2005 17:14:56
 Re: The Ultimate Dream Shop in reply to RustyFarmall, 12-14-2005 08:28:48
I had a 48' X 42' Morton put up last year. It took them 4 days from start to finish, not including the dirt work, and another 1/2 day to pour the slab. EXCELLENT job from start to finish. Expensive, maybe, but you get what you pay for.
I bought it because of their reputation as well as the guarantee.
Jay (ND)
12-14-2005 09:56:21
I think it depends on who runs your franchise. Up here, Morton is second to none. Fit & Finish is perfect. It takes a week or so to erect. They show up with their own truck sized dumpster for the scrap and their own porta pottie. Their crews and product exemplifies professionalism.
Randy_NE
12-14-2005 09:01:53
WoW RustyFarmall! That's interesting. I have a few farmer neighbors that were very happy with their Mortons, fairly large machine sheds done in about 2 weeks,
I have not got a price yet, but the Morton guy came out last week so I guess I will have some comparisons.
Randy
RustyFarmall
12-14-2005 12:02:06
 Re: The Ultimate Dream Shop in reply to Randy_NE, 12-14-2005 09:01:53
My local Morton franchise was the problem, no doubt about it, but at least half of my problem has to be blamed on the corporate people, I wrote letters, talked to them on the phone, and they pretty much laughed right in my face. If I had it to do over again, I would not have paid that final bill until we had some lawyers involved.
Midwest redneck
12-14-2005 07:34:48
Plan it out well, dont do what I did. My ceiling is too short, not enough windows, bla, bla, bla. Mine was about $22,000 that is with a drywalled workshop insulated too.
the tractor vet
12-14-2005 07:23:17
First off make it high enough and if your thinking that a 40x50 is the size ya need better set down and do some scale drawings and figure in for work benches tools along the walls size of equipment and vehicals that you plan on putting in there and rhen see what floor space is left , will it be heated all the time when it gets cold out? or just when working in there what kind of lighting are you planning on . what kind of doors, for a work shop with heat nothing but and insulated overhead to much heat loss with a sliding and with and overhead you lose head room unless you go higher and no matter what you put up a year or so down the road you are going to say i wished that i would have done this or that been there done that . My buddy and i are in the planning stages of one now and we need machine storage and a shop now for just the shop area we can get by with a 40x50 but it will have to be atleast 14 foot inside hight maybe 15 that way we have the clearance for the door and good lighting and since there is FREE gas we will go with the radiant floor heat and start the heat when it drops below 60 degrees .
Brian S, NE
12-14-2005 06:42:34
Randy,
I am in exactly the same siutation. Have you looked at the kits from Menards?
Where in NE are you located? I'm outside Omaha.
Brian S, NE
Silver Pig
12-14-2005 17:17:37
 Re: The Ultimate Dream Shop in reply to Brian S, NE, 12-14-2005 06:42:34
You might want to look at HardSteel. They are located at Decatur or Tekamah.
Randy_NE
12-14-2005 06:56:50
I am NW of Lincoln.
Yes I looked at Menards and got some pricing.
The link from kirk / ihcollector looks interesting, I see they will dig holes, set poles, and trusses on the 30x50x10' pole barns for $1,495.00 which would be the hardest part for me. I would need to check them out for references before going to far.
Randy
kirk / ihcollector
12-14-2005 06:23:10
FYI Nationwidepolebarns.com has a 30X50X10 for $7195. with free shipping. They are located in Dayton, OH
Johnbob
12-14-2005 09:46:23
 Re: The Ultimate Dream Shop in reply to kirk / ihcollector, 12-14-2005 06:23:10
Insulate well including the floor,use floor heat,put in twice as many electric plugs that you think you may need and double that.
I would stick build even if it costs more.We have several pole buildings that are getting some age on them and the posts are rotting off.
