Tool Talk Discussion Forum
Need input on moving a surface grinder...
Midwest redneck
12-13-2005 06:14:01
I will be buying a surface grinder in a week or so I put a $100 deposit on it already. I am going to get 10--2X4's and make a sturdy pallet and then block in the grinder on top on the 2x4 pallet. And use rope to tie it down to the pallet. The grinder is a 6-18 surface grinder, weighs about 700 lbs. Anybody got better ideas to do this. any input on this would be appreiciated.
Davis In SC
12-13-2005 09:42:23
 Re: Need input on moving a surface grinder... in reply to Midwest redneck, 12-13-2005 06:14:01
What brand of Grinder is it??? Reason I ask, is, if it has a Ballway table, there are special precautions to take...If it has regular bedways, hauling it is no problem... Regardless of table style, block & secure the table, so it cannot slide from side to side... Years ago, I was moving a Cylindical OD/ID grinder, the table slid off & broke a huge hole through the body of a Ryder truck that only had 300 miles on it.... Glad I had paid the 15.00 insurance ...
Midwest redneck
12-13-2005 16:11:39
 Re: Need input on moving a surface grinder... in reply to Davis In SC, 12-13-2005 09:42:23
It is a Reid grinder, it may 1000 lbs. or so. I cant see it being more then that, a Bridgeport series 1 is 2000 lbs and is a lot bigger. The box truck is GMC 4500 with slots for strapping on the side of the truck.
Davis In SC
12-13-2005 16:24:48
 Re: Need input on moving a surface grinder... in reply to Midwest redneck, 12-13-2005 16:11:39
If I am not mistaken, the Reid Grinder has the table running on balls... if so, the table should be taken off , before transporting... the vibration from shipping can distort the balls, & press indentions into the runways. You should be able to look under the table & see if it uses ballways.. I think the weight might surprise you...Those grinders used some massive castings...
Doug in IL
12-14-2005 06:56:23
 Re: Need input on moving a surface grinder... in reply to Davis In SC, 12-13-2005 16:24:48
The older Reid's like the model 2C and Model 618 have plain ways. The newer Reid's did have roller ball ways. I think the Reid's with rollers were named "Rollaway" grinders, or something close to that. By the way, the Model 2C weighs 1100 pounds and the Model 618 weighs 2000 pounds. These were both hand operated grinders. The newer hydraulic grinders would be heavier.
Midwest redneck
12-14-2005 01:34:56
Okay, I will look into the weight of the machine. As far as the table on balls, Would not the balls be hardened? plus if I strap the table down it should not bounce.
eeleater
12-14-2005 04:50:50
 Re: Need input on moving a surface grinder... in reply to Midwest redneck, 12-14-2005 01:34:56
The balls being hardened will not prevent the brinelling from vibration. It will not matter if the dents are in the balls or the ways. It will show up on the finish you get either way. Strapping it down might work. It also might not work. The tighter the straps are the greater the chance THEY will contribute to dents (though I admits this is much less likley).
Why take the chance?
Midwest redneck
12-13-2005 07:40:58
 Thanks, you guys gave me more ideas. in reply to Midwest redneck, 12-13-2005 06:14:01
I will use straps, I need to get some and lowering the spindle to the chuck helps. I will be using a GMC7500 box truck, enclosed van type.
Ken Crisman
12-13-2005 12:04:22
 Re: Thanks, you guys gave me more ideas. in reply to Midwest redneck, 12-13-2005 07:40:58
Ropes to hold it onto pallet . Makes no sense . The pallet construction - good . You better bolt it down & use binders for added security . One slight shift from road traveling issues will make a nightmare to remember or hurt someone . I heard of something similar done years ago & the machine actually came through the cab & killed the driver . Good luck & Merry Christmas. Ken
LeJo
12-13-2005 07:22:02
Previous two writers , both have good suggestions.
I would double check that weight, am suprised it is so light weight. Also move spindle as far forward as possible. These beasts are very top heavy and will go out the side of any carrier if you take a corner to fast. Also make sure you have that table stabilized. If for some reason you have to hard brake,that table might find it's way into the cab of your pickup. Good Luck
Bill WI
12-13-2005 06:54:26
There should be holes in the corners of the base to bolt it to the skid. I'd use straps with ratchets instead of rope. If hauling open, put a twist in the straps to keep the wind from playing with them. Center the table and take the grinding wheel off and run the head down on block on the magnet or table. Remember a cylinder or straps move the table back and forth, but it is just riding on the ways and can be tipped off costing $$$$$$. Good luck. I'm sure there'll be more ways.
Doug in IL
12-13-2005 06:51:18
Keep in mind that on many surface grinders the table basically just sets on the ways. I've hauled them in a pickup before by setting them on a couple 4x4's and strapping them down real good. My pickup has 4 good tie down loops in the bed. Loaded and uploaded with a forklift.
