Compression on a craftsman chainsaw
Stosh
02-12-2001 06:50:57
I have an old model 3.7/18" from the 80's and would like to know what the cylinder compression should be around. Also what the gas&oil ratio mix should be.
T_Bone
02-12-2001 19:30:20
 Re: Compression on a craftsman chainsaw in reply to Stosh, 02-12-2001 06:50:57
Hi Stosh, Around 1980 most of the saws were pushing for 40:1 mix that I was looking to buy. I have a Mac Pro 610 I bought in 1980 and recomended was 40:1 but I've always used 25:1 and 21yrs later it still cuts 6 to 7 cords a year and is in great shape. At 25:1 it doesn't smoke too bad.
As Al said around 100psi or higher is good for all gas combustion engines. I have a 318ci Dodge water truck that had 50psi on 6cyl with 30psi on the other 2cyl. It would start if choked completely as that was the only way I could get it to siefen gas out of the carb to start. Once running about 20mph was tops but it lasted several years that way before I could get time to rebuild it.
T_Bone
Al English
02-12-2001 10:25:09
Hi Stosh, There is some discussion about this a few posts down. I remember the unmodified 2-cycle motorcycles I've worked on being in the 90 to 100 PSI range. On the other hand, Bill says in his post he has a saw with 60PSI that runs fine.
The oil mix depends on the oil you're using. The traditional ratio with conventional 2-cycle oils is 16:1 which is 1/2 pint of oil per gallon of fuel. There are "special" 2-cycle oils that are mixed at 80:1 or more. There could be something better, but I've had no problems with the oil Stihl sells with their name on it. Based on his observations, my friend who works on small engines recommended it to me. I have an old Sears saw, a larger Stihl saw, and a trimmer that have many hours on them using this oil, and I also use it in another trimmer and a leaf blower. I may get some disagreement on this, but I would stay away from the synthetic 2-cycle oils. The advantage of these oils is that the engine can be made to produce more power, and spark plug life is improved. But among the problems are shorter engine life and reduced corrosion/rust prevention. I've seen the results of these problems first hand, and have discussed this with two manufacturers of synthetic 2-cycle oils. One of them told me that using their synthetic oil, an engine lasts 60% of what it would with conventional mineral oil. Mobil 1 has finally reached a point of being the best oil there is for some 4-cycle applications. But unless you are racing your chainsaw, don't use synthetic oil in it...Al English
