Tool Talk Discussion Forum
Sperry Wiggy
Dale B
12-11-2005 13:49:13
I bought a "Sperry Snap 6" wiggy at a yard sale yesterday. It has an ohm meter function that doesn't work, so I took it apart to replace the battery, and I can't find it in either half of the unit. Is it some kind of micro watch battery? I don't even see a place to put one ! Of course there was no manual with the unit..... Thanks in advance, Dale
Jim K
12-11-2005 15:40:15
 Re: Sperry Wiggy in reply to Dale B, 12-11-2005 13:49:13
What I asume that what you have is a Sperry clamp on ampmeter slash vom. Wiggy is a whole different animal.
You have to get the lead which has the battery holder which connects in series with your positive lead, not sure about Sperry but Amprobe uses a hole on the side of the unit to plug into when using the Ohms function.
you should be able to get it from just about any supply house.
Dale B
12-11-2005 18:54:38
 Re: Sperry Wiggy in reply to Jim K, 12-11-2005 15:40:15
Jim ,yes it has an amp clamp and a standard VOM type meter. what is the voltage of the battery ? I could make my own test lead if I knew the battery voltage. Also, what is a "Wiggy" ? I'd heard amprobes called that before, and the guy I bought it from used the term for this one. Is it the type with the colored scale and an indicater/plunger that runs parralel to the scale ?
Jim K
12-12-2005 15:17:23
 Re: Sperry Wiggy in reply to Dale B, 12-11-2005 18:54:38
All you need is a 1.5 volt AA battery.
What we refer to as a wiggy around here is any voltage tester that uses a coil with a plunger.
Bill in IN
12-12-2005 07:53:48
Wiggie is short for Wiggington tester which is a low impedence solenoid type tester manufactured by Square D.
