We built new 3 yrs. ago. Installed a central vac and have been thankful ever since. Power Unit mounted in the garage and has an extra port for vacuming out the rigs. We have 2 kickplates (entry doors - main and garage)and various outlets throughout. Get the hose cover to save your baseboards when dragging the hose around corners. Would have liked to install 1 more kick plate in the kitchen so just a quick sweep and done. Other considerations - Install speaker wires throughout house for full home stereo. This is great especially during holidays. Oversight was not installing wires in the walls for surround sound in TV area. Install multiple coax cables (home runs) into each room, also consider some coax drops from the ceiling for wall mounted TV. Got 4 drops plus exra outlets on each wall of major rooms. Then TV and VCR can be hooked up in a variety of locations in the room. We have satillite. Can also use the coax connections for cable modem. Oversight was not installing ceiling drops and power outlets for wall mounted TV for bonus room. Install pest control vent tubes in the wall. Then you can be your own exterminator without the "bug juice" on the floors and baseboards. Aerosol pesticides now available across the counter. Also if rafters permit add plywood now so you have full attic floor to store stuff. They can shoot the insulation under the plywood. If you can afford it consider dimmer switches vs. on/off to create lighting effects in the house. Contractor can buy them cheaper than you can. Oversight was thinking we would do later and then found out the cost of switches. This is an on-going effort right now. I also have deep sink installed in garage to clean veggies, canning, gutting fish from the pond etc. Keeps Momma happy and if she is happy so is everyone else. HTH, ShepFL
