Tool Talk Discussion Forum
Try incandescent -flourescents CFLs
jdemaris
12-09-2005 17:38:45
If you want to try a screw-in replacement for the bulbs you have now, there are some new-generation bulbs that are flourescent and incandescent at the same time. Home Depot and several other places have them now. They are the "twist" shaped compact flourescent bulbs and are rated down to 0 degrees F. They also have them rated to -20F but those cost more. They don't use a ballast, but actually have a filament that has a flourescent coating. Since they have a filament, they don't flicker any more than a standard incandescent bulb because the filament retains enough heat during the 60 Hertz cylcles every second to stay bright. A gas tube does not, cools off every 1/60th of a second, and will flicker slightly unless it has a very good electronic ballast. 23 watt bulb puts out 100 watts of light. Home Depot has been selling six packs for $10. That's the cheapest I've ever seen, I suspect the Chinese company that's making them is dumping them on the market at cost just to get their name out. Odd thing is, Home Depot has the bulbs in one-packs and they're $6 apiece. Walk to the other side of the store, and the same bulbs are in the 6 packs for $10.
The Chinese Company sells via TCPI, their site is at: Link
