Attn Terry-Poulan Saw
Al English
02-11-2001 07:07:43
Hi Terry, For some reason I was unable to submit a response to your original post. I think Bob has you on the right track, but just in case, give this a try. I have a small Sears saw that was made by Poulan. It is adjusted correctly, runs fine, and has none of the problems Bob mentioned. Since I bought it new over 25 years ago it has tended to do the same thing as yours. Next time it won't start try a pull or two with the choke on, then open the choke & see if it will start. I have no idea why this works, but I suspect it has to do with the fact the carb also pumps fuel to itself. Hope this works for you...Al English
