Chainfall/chainhoist?
JoeK-confused
02-09-2001 11:22:03
Was reading earlier posts about chainfalls and???.I have an(antique?)old unit by Chicago hoist which has one continuous chain loop in it.It will extend appx 12-14 feet before the "control" loop of chain gets used up.It is 1000lb cap with hooks on both end pulleys.Is this some oddity or variation or is this the difference between a chainfall and chainhoist?
"Still learnin til they nail the lid down"
chez
09-04-2002 22:23:38
 Re: Chainfall/chainhoist? in reply to JoeK-confused, 02-09-2001 11:22:03
hi
Paul J. Decker
02-10-2001 04:06:02
The type of hoist you mentioned with one continuous loop of chain is called a differential hoist. The upper wheel has two "sheaves" that differ in tooth count by one. Each revolution either picks up or lets go of one chain link and lifts at that rate. They are limited to lighter loads unless the chain is very fine (not practical for heavy use). I have one and a heavy V-8 engine is about all it can handle.
Vern
02-09-2001 22:10:45
I believe that you have a "chain hoist".
A chain fall is where the pull chain is seperate from the hoist chain.
JoeK-THANX
02-14-2001 08:38:12
 Re: Re: Chainfall/chainhoist? in reply to Vern, 02-09-2001 22:10:45
Don't use hoists of anykind much,other than this old one I've had forever and a couple of "comealongs".Guess I just never realized there were different types...Thanx again.
"Knowledge is never wasted"
