Tool Talk Discussion Forum
Propane Heaters
rwood
12-04-2005 10:35:14
Just got a propane heater for the shop. How much ventilation do I need to avoid asphyxiation? Thanks.
Coal Miner
12-05-2005 16:12:16
 Re: Propane Heaters in reply to rwood, 12-04-2005 10:35:14
Keep a canary in the building with you while using the propane heater. If the bird falls to the ground suddenly, get out quick!
JD9295
12-04-2005 14:26:15
How air tight is your shop. If its like most you will probably be ok the way it is.
Good thing to have if in doubt is a co monitor, put it 5ft away from the heater and see what it does
Ben in KS
12-04-2005 18:23:45
 Re: Propane Heaters in reply to JD9295, 12-04-2005 14:26:15
What kind of propane heater is it? I have a radiant, overhead type that doesn't require much in the way of venting. Some forced-air "torpedo" types build up the CO and fumes pretty fast. There should be some guidance offered in the manual that came with the heater. HTH Ben
JD9295
12-04-2005 14:20:47
