Tool Talk Discussion Forum
Cap Screw and Bolt???
Robert in Md
12-03-2005 19:47:32
Just curious, whats the difference between a cap screw and a bolt?
John Garner
12-04-2005 10:18:34
 The difference? Simple . . . in reply to Robert in Md, 12-03-2005 19:47:32
Robert --
In the Mechanical Engineering world, a bolt is a headed fastener that takes a nut whereas a screw is a threaded fastener that directly engages internal threads in a larger part that has some function other than simply holding a bolt in place.
John
Jim K
12-04-2005 07:55:43
 Re: Cap Screw and Bolt??? in reply to Robert in Md, 12-03-2005 19:47:32
I always thought that a hex cap screw was an Allen Head bolt.
JMS/MN
12-04-2005 16:12:51
 Re: Cap Screw and Bolt??? in reply to Jim K, 12-04-2005 07:55:43
I've always referred to an Allen head bolt as a hollow head cap screw, and a hex head would be referring to a bolt with six flat surfaces on the outside of the head, unlike that of a carriage bolt.
Rod (NH)
12-03-2005 20:36:08
Hi Robert,
A cap screw is a bolt with a more carefully controlled body diameter. The body is that area between the end of the threaded area and the bottom of the head. For example, a hex head bolt of 1/4" nominal size has a body diameter of 0.260" maximum. A hex head cap screw of the same 1/4" nominal size has a body diameter within the limits of 0.250" maximum and 0.245" minimum. This is from ANSI B18.2.1, Square and Hex Head Bolts and Screws, Inch Series. A cap screw will typically have a fully machined unthreaded shank where the bolt will have an unthreaded shank that is in the as-rolled condition. Hex cap screws are sometimes called "finished hex bolts".
third party image Rod
jerrycpp
12-06-2005 12:04:19
 Re: Cap Screw and Bolt??? in reply to Rod (NH), 12-03-2005 20:36:08
For special applications such as mounting clutch pressure plates, we had what were called "body fit" bolts. The unthreaded part was a bit larger diameter than the threads. Are these the same thing?
