Tool Talk Discussion Forum
electronic doo dads
paul
11-30-2005 10:22:53
I see more & more tools with a battery & something electric on it. Levels, squares, tape measures, etc. Even power tools, with little 'features' added to them.
What do real tool users think of this stuff?
Seems just odd to me. My tools sit in unheated buildings here in Minnesota, need to work when I need them, and can sit for a few months when I don't.
Can't see the need to have to find a battery before I can use my level!!!!!
Will this stuff replace real tools?
--->Paul
Slowpoke
12-08-2005 00:34:06
 Re: electronic doo dads in reply to paul, 11-30-2005 10:22:53
I agree about the cordless drills as number one, but I'm also very happy with my digital level. I found it in a thrift store about 10 years ago. It's about 8" long, and I believe it is the center part of a longer 24" level frame, which made it kind of 2 levels in one. It measures in inches/foot, percent, and degrees by tenths. It works vertical, horizontal, anywhere in between , even upside down. I seem to remember having to change the button battery once. I can set it on top of a long bubble level and compare the readings, or use the digital readings.
Scott.ID
12-02-2005 09:59:50
My favorite is the power in/out tape measure.
Can you imagine not being able to measure a 2x6 without fresh batteries?
Scott
dr.sportster
12-01-2005 07:25:09
The key is to keep a pack of industrial batteries in your toolbox.Whats easier to climb up and down a ladder or to lay-out ceiling work on the floor and use a laser plumbob.To get out your flashlght or push a button on the level so you can see it in the dark.Or to get out 200 foot of extension cord for one cut or use a battery sawzall.Is it easier to use a laser level to see any obstructions in a pipe run ahead of time or wait until the options are limited.Not to mention hobby uses like motorcycle wheel aligment.Once you have these tools you will find plenty of time and labor saving uses.[I dont actually own them myself I still use masons line.]But they will come in handy.
Dave NE IA
11-30-2005 20:29:04
MY 2 cents--Battery powered drill-very good, but 2nd on the list is the bullseye laser ( under $50.00), the bright orange one. They make 2 models one is self leveling for horizonal only--greater than the toilet paper invention. The other is a self leveling for horizonal and vertical at the same time and you can lock it for a big red beam square that will extend indoors with lights dimed probably 40 ft x 40 ft. Again under $50.00) As far as the stud finders, I have in excess of 12-15 wonder machines that simply work best in the bottom of a dumpster--we use the $2.00 little magnet one so we know exactaly where the stud is. I do have the red sun glasses for lazers as they help my failing eye sight--they actualy make a big differance in visability of the red beam.
Davis In SC
11-30-2005 19:07:40
Most of those new electronic tools do the job they were intended to do... Getting the consumer's money... I wonder how many "Non-tool" folks go, out & spend big money on all these laser gizmos, to hang a picture or 2... So they can think they are on "This Old House", or something... Just more junk to clutter up things... I was in Home Depot, a while back, Stopped to look at the tools, & thought what a bunch of garbage these new gadgets are...
Stan in Oly, WA
11-30-2005 17:54:07
Hi, Paul
I agree with everyone so far; the cordless drill is one of the best tools to come out in my lifetime. Otherwise, the simpler the better. I wouldn't care if the electronic thing that makes my framing hammer also a global positioning device and avocado seed remover wouldn't take the hammer down with it when it fails. But they always do. When a digital thermometer fails, it doesn't revert to being a regular analog thermometer, it becomes brand new landfill.
A tool that has most of the qualities I'm looking for is a splitting wedge. It's sturdy, has no moving parts, and is large enough to be easy to keep track of. What it lacks is versatility. If it could only do something I needed done, I'd have to rate it as just about perfect.
All the best, Stan
JoeK
11-30-2005 21:09:29
 Re: electronic doo dads in reply to Stan in Oly, WA, 11-30-2005 17:54:07
I got a 16" piece of antique railroad rail that ranks right up there with yer wedge,dozens of uses from anvil to blocking to short stool and also serves excellantly as a BHT(big heavy thing) :)
Kelly Campbell
11-30-2005 14:03:55
About the only two electic (battery) tools that I really use on a regular basis are a cordless drill and a Zircon stud finder. I have a friend that has a laser level that you can attach to the wall. Its pretty handy but the bubble to level it is not really accurate.
To answer your question will it replace real tools, I doubt it, To me there is something to be said about quality tools that can stand up to the test of time. For example, my family still has all of my great grandfathers barn building tools and the tool chest that he kept them in. The chest it self is starting to show its age a bit, however, the tools inside have all been wrapped up in cloths and saws wraped in newspaper. All of the tools are just as sharp and as clean as the day that they were put away. There are no battery operated tools in there and if needed they could all come out of retierment and build one heck of a barn.
So in the end feel as though nothing will ever replace a real tool.
Just 2 cents worth,
Kelly Campbell
Dusty
12-01-2005 05:19:05
 Re: electronic doo dads in reply to Kelly Campbell, 11-30-2005 14:03:55
This remindes me of what some one once told me. It used to be that a carpenter made his tools, today tools make the carpenter.
Dusty
RustyFarmall
11-30-2005 11:23:37
I finally gave in a few years ago and bought a cordless electric drill, it is one of the handiest tools I have, provided I have remembered to put the spare battery in the re-charger. I really don't think I will ever need a tape measure with a digital readout, or one that uses a laser to do the measuring. I also can't see the need for the electronic laser level. In my opinion this kind of stuff is nothing more than an attempt to sell tools to people who really don't know what they are buying or how to use them, and I really doubt if very many of those electronic doo-dads will ever see any actual use. I don't need them, I don't even want them.
