Tool Talk Discussion Forum
Cutter blade for metal in my electric saw
Willy P
11-28-2005 18:49:31
Do they make a blade that will cut 3/16 plate steel that will fit a electric saw? I am talking about a hand held saw. I need to cut some steel plate and I don't have a plasma cutter. We use these saws to cut tin by turning the blade around backwards,works good just noisy. Of course that wouldn't work for steel plate. Thanks
Tim B From MA
11-30-2005 09:29:07
 Re: Cutter blade for metal in my electric saw in reply to Willy P, 11-28-2005 18:49:31
My dad gave me a Black & Decker carbide tipped 7 1/4 inch saw blade a few years back. A relatively fine-toothed (40 teeth maybe) all around carpentry blade.
I cut through two two-inch sections of the steel frame of my Work-Mate saw bench(maybe 14 ga steel) and didn't even notice. I also cut through two 1/2 inch steel bars when cutting an old maple 5 x 4 shop bench top in half to make two benchs - again I did not even notice I was cutting steel, and the blade seems as sharp as new.
I've been thinking about just using it on steel when needed -seems to do the trick!
When I have cut steel on purpose I use the $2 - $3 abrasive blades you can pick up any where. I am thinking about a carbide tipped blade for metal though. I'm sure it is faster, cleaner and won't stink up the garage.
Uncle
11-29-2005 13:17:13
I bought two from Amazon that fit my worm drive. $30 including shipping.
I love them.
ben a
11-29-2005 04:35:03
Willy: Freud makes a metal cutting blade that will fit a 7 1/4" circular saw. I've used it before and IMO it will cut a piece of steel like a hot knife thru butter. good luck
Chris(WA)
11-28-2005 21:10:04
Here is a link to their bigger saw rated at 1/2 " steel.
Chris(WA)
11-28-2005 20:51:13
There is a saw that will cut steel like you are talking about. Has carbide teeth. Called a Steel Max. It was a bit pricey but it did what no other tool I have seen could do. I always thought about buying just sa blade and trying it in a saw. The steelmax saw runs slower than a standard circular saw so never tried the experiment. I have seen ads for a Sears saw that advertises the same cutting. It has two blades that rotate in oposite directions. Never have seen one operate though.
hawaiirocky
11-29-2005 22:33:48
 Re: Cutter blade for metal in my electric saw in reply to Chris(WA), 11-28-2005 20:51:13
I have one of the two-bladed saws from Sears. It won't work for you. I burned one out just cutting a thin aluminum plate about three foot across. I returned it and have a new one in the box that I'm afraid to use. It appears to be nothing more than a little hand-grinder motor with a fancy cutting head with $50 dollar blades.
SHeiserman
11-28-2005 19:25:08
Have access to a sawzall? A tapered wood blade in a sawzall works great. I'd recommend Lenox blades. Run the saw about half speed, and let the saw do the work. Don't overheat the blade and you'll be fine.
NC Wayne
11-28-2005 19:15:37
I just looked at one the other day that will cut up to 1/2 plate all day long. I'd love to have it but it's a tad over $600 so it's a bit out of my range for no more than I'd use it. As thick as your plate is you ought to be able to do it with a torch with no problem. If you want a straight line clamp a piece of angle iron down along the cut line to use as a guide and use a small tip, say a 0 or 00 to keep the heat input down. Keep the torch head parallel to the line of cut so the edges of the kerf are at 90% to the face, but angle the top back a little toward the beginning of the cut to make the actual depth of cut a little more than 3/16. Doing it this way you ought to be able to cut along fast enough to prevent warping it and get just as clean a cut as you would with a plasma. Good luck.
old
11-28-2005 19:05:46
I use a metal abresive blade on my circler saw all the time. I have cut steel up to 1/4 inch thick with that set up, its slow but does the job. Of course depending on how much you have to cut it may take more then one blade. There sort of like 7-1/4 inch chop saw blades. Last I checked wal-mart has them for around $3 each. I always keep one or 2 around in my shop.
