Tool Talk Discussion Forum
Hydralic jack conversion
Itchy
11-28-2005 11:01:12
I have a 30 ton jack on a press..it has a 1/2 pipe where the handle mechanism works. Can I remove that 1/2 pipe and insert a hose and connect that hose to a separate hyd-system run by a elec motor and pump to supply the press cylinder with oil? I hope this can be done with out replacing the cylinder. I know there is a system that works this way...I just want to keep my cylinder...Thanks to all.
drw
11-28-2005 20:23:01
 Re: Hydralic jack conversion in reply to Itchy, 11-28-2005 11:01:12
Maybe yes, maybe no....Do you have a model on the handjack itsef or on the complete press? If its Chinese, there is a longshot that an add-on air motor will do the trick-uses the exiting unit's oil reservoir & check valves. If it's U.S. made then your chances are slightly better;
e.g. on a Black Hawk 30 ton you can go in through the gauge port with your idea pretty easily. Other models get a little tricky. May be more $ than you think, but worth it if you use the press quite a bit.
Charles (in GA)
11-28-2005 14:48:35
As I understand this, you want to unscrew the pump body off the jack, removing the pump body and piston and install a pipe fitting and plumb it to a power pump?
Problems, there is most likely a check valve assembly about the size of a nickle at the bottom of the pump bore. It allows fluid in from the resvoir and allows fluid out to the ram and keeps pressure from coming back into the pump reservoir. This would have to remain in the jack, in which case you would have to have something to screw down tight on top of it like the original pump body did, to make it seal, so you don't have internal leaks.
Secondly, when you release the valve on the jack to collapse it, the fluid from the ram is returned to the reservoir, and not to your external power pump. You would have to remove the fill plug from the side of the jack and install a fitting to allow overflow from the jack to return to the external pump's reservoir.
Just doesn't seem real practical to me.
Charles
Itchy
11-29-2005 05:47:51
 Re: Hydralic jack conversion in reply to Charles (in GA), 11-28-2005 14:48:35
Charles...I think you are right..I know someone makes a bottle jack that has a hose connection on it, and slide it under the vehicle and use a hand pump to raise the vehicle. I thought maybe a regular jack could be converted. Thank you for your input.
