Tool Talk Discussion Forum
homelitexl101
mark inks
11-27-2005 14:47:34
homelite xl 101 overfuels i have overhauled carb only thing i didnt do was remove the welch plugs.i was just wondering if there is a common problem with these saws? i have a xl 113 that acts about the same.
JT
11-28-2005 06:06:04
 Re: homelitexl101 in reply to mark inks, 11-27-2005 14:47:34
Is it overfueling or do you have a igntion problem that does not have a hot enough spark to fire the fuel completely?
jdemaris
11-27-2005 15:22:45
You ARE referring to the 101 that preceded the XL12, is blue colored rather than red, and is maybe 35-40 years old? If so, I don't recall if it had the Walbro or Tillotson, but either way there's nothing under the welch plug that can make it run rich. If a plug is loose and leaking, it can. Are you sure it's the carb. overfueling, or is the saw unable to use the fuel properly? Those saws back when fairly new, and even more now, often wore out piston grooves and broke reed-valves. I worked for Asplundh Tree Experts back in the 1960s, and for awhile, Homelite was all we used. When we started using Stihls in mid-70s, it was like going from a Model T to a Cadillac. No offense to Homelite - it was a great company at one time - and I still have my old 4-20 and Super Wiz gear-drive saws.
