Tool Talk Discussion Forum
Water leak under concrete
Terry G
11-26-2005 17:47:29
I have a water leak under the concrete slab in my house. Has anyone ever used one of the leak detection services? They claim they can locate the leak within 3 inches. If they can locate it then I plan on busting a hole through the floor to repair the copper line. I have had two more leaks in the last 3 months. One in the wall feeding the bath tub and one in the wall feeding the hot water heater. Both were just pin holes in the copper and the copper looked solid everywhere but a small spot where the leak was. I don"t mind busting up the floor and fixing one leak but I am wondering if there will be more to follow. Has anyone had any experience with this? All suggestions are welcome.
Thanks,
Terry G
plinker
11-30-2005 09:30:19
 Re: Water leak under concrete in reply to Terry G, 11-26-2005 17:47:29
Had three leaks in cement slab, over 4 years. Two in hot water lines where constant expanding and contracting would eventually erode pipe against the rough cement, to cause a small pin hole.
Once you get one in the slab..... ....just repipe all the slab lines. If you have insurance and want to file a claim, sometimes you can get the plumbing company to apply that repair money to a re-pipe job. Some companies also do water line re-lining.
RayP(MI)
11-27-2005 16:06:18
We had problems with one copper line which ran to the humidifier in the furnace. Several different lines developed pinhole leaks over the years. Our best guess is electrolysis. If the copper is cemented in, you're probably going to have more problems. Probably best to replumb all. Have you considered some of the new plastic lines?
Paul Shuler
11-27-2005 13:05:04
Just put a new copper line from our propane tank into the back of the house. Where it goes under the patio slab the propane man said it must be in plastic conduit cause the concrete would eat a hole in it in no time.
jeffcat
11-27-2005 09:39:29
Had one leak like that myself. Copper stinks if you have acidic water. You need a fiberglass tank with lime chips in it. That takes care of it. Jeffcat
Jerry F
11-27-2005 09:17:15
This happened at my fathers house about 1995 and his house was built in early 80's. He was told this was a common problem from houses built then with slabs poured over the copper pipes. I dont remember what the reason was whether it was a copper problem or a cement problem. But I now know that houses around here dont get built with copper in contact with the slab anymore. He went through the same thing with at first, one leak fixed, then another. He ended up having the whole thing re done with all new pipe in the walls and attic. It was a lot of bucks but couldnt get around it.
Dick2
11-27-2005 07:51:12
Do you have municipal water? There was an article a few weeks ago that municipalities were/are using a different chemical instead of chlorine that is eating holes in copper pipes.
I had a leak detector locate a leak under our concrete garage floor and mark it. The plumber called me at work and said he couldn't find the leak - then admitted that he couldn't even find the pipe. Turned out that the pipe was almost 4 ft. deep, instead of the 2 ft. depth on the drawing - the leak detector was right on the spot!
Charles (in GA)
11-26-2005 18:55:40
Corrosive well water? Pipes not in plastic sleeves in the slab (portland cement is very corrosive).
I agree with one post that three leaks is too many. I'd consider replumbing with CPVC thru the attic, insulating if necessary, depending on your climate.
Charles
Truck
11-26-2005 18:55:05
If you are in an area where the water itself is corroding your copper tubing, ask the local plumbers what to replace with.. and plan on replumbing the entire residence over the next few years....I went thru this on my bro's rental property out in Arizona. The water ate up all the metal pipes and fixtures eventually. I beleive we used PVC schedule 40? plastic for most of the retrofit work we did.
I wouldn't mess with finding the leak if you are dealing with internal corrosion. Just replace it all, and put it in the attic or somewhere accessible.
Hermit
11-26-2005 18:50:57
If the pinhole leaks are occuring on the lower side of the pipe, it might be flux-induced corrosion. If the person who soldered the pipes together used too much flux, some of it got into the plumbing and was not flushed out. The flux settled to the lower points in the pipe and start corroding, leaving scattered pinholes in the pipe. After you cut out the leaky pipe, try to determined what caused the pinhole. If it was flux-induced corrosion and a licensed plumber installed the piping, you might have a legal recourse to get some of your repair cost back. Good luck.
bo
11-26-2005 17:58:57
3 leaks...unless you're going to sell and move real soon, you might as well re plumb it all through the attic. It'll be a chore but you won't be chasing plumbing that's wore out. Wonder why it got pinholes in it. Under the slab, the copper is reacting with something in the slab.
Bill in TN
11-28-2005 04:56:39
 Re: Water leak under concrete in reply to bo, 11-26-2005 17:58:57
I spent all day saturday under the house..... .pin hole leak in a solder joint.....looks like most of my joints are in bad shape..... ..
Took me all day because I didn't know what I was doing..... ....my solder joints for the replacement piece that I made outside were fine..... but when I tried to solder it to the existing pipe under the house it would leak..... ..finally got it on the forth try..... .
used a shop vac and vacuumed as much water out of the lines as I could..... .I was using a propane torch.....thought that might be part of the problem, but I believe that water in the lines was the source of my head ache..... .
I can do most anything, but for what ever reason, plumbing is hard for me..... ....especially with copper..... ..
The SIL recently got a $3000 water bill..... had a leak between the condo and the meter..... used 120,000 gallons of water.....the meter was on the other end of the building and he didn't know about it until he got the bill.....we think the bill was estimated for a couple of months and the meter read once a quarter.....
He and I spent a saturday digging up line and we never found the leak.....broke a neighbors line in the process and had to repair it..... Finally called a leak detection specialist..... he found the leak.....it was under the side walk..... ...oh the joys of home ownership.....
Condo home owners association contracted a landscape company to haul in some 22 tons of dirt.....they drove over the meters, broke the sidewalk and we're pretty sure that's when the leak started..... ....they refuse to help at all..... .they say the home owners association is not responsible for the water lines and there is no proof the truck caused the leak..... ..the bill is about what a lawyer would cost..... so I don't see how he'll win..... he'll just have to pay the bill..... .
