Tool Talk Discussion Forum
measuring AC voltage with DMM
user
11-25-2005 12:18:00
Is it safe to measure 110V AC with a DMM multimeter? I work with DC alot, AC scares me a little. Meter has an AC voltage setting.
John
RandyBee
11-25-2005 16:20:42
 Re: measuring AC voltage with DMM in reply to user, 11-25-2005 12:18:00
Yes the meter is safe if you follow the normal safety rules like using insulated test probes and keep the fingers off the tips. When you say you have been working with DC - do you mean that you have been working with low voltage DC like 12 or 24 volts? If you have been working with high voltage DC, then the same safety rules will apply to DC. Electricians and technicians use DMM's every day measuring AC voltages.
MarkB_MI
11-25-2005 14:26:53
Sure, as long as you don't exceed the maximum input voltage, which is normally marked on the input jack. Most modern DMMs are good up to at least 250 Vrms. For higher voltages you'll need a high voltage probe.
user
11-25-2005 16:21:16
 Re: measuring AC voltage with DMM in reply to MarkB_MI, 11-25-2005 14:26:53
Good deal, Thankyou.
