Tool Talk Discussion Forum
Antifreeze in oil-What does it do to motor?
Rick Reeves
11-23-2005 14:30:15
I think a seal in our JD-450 bulldozer blew and antifreeze (probably more than less) got into the engine oil. Does it mean that a motor is ruined if it started running with knocking and strain? What do you do from here?
Rick Reeves
11-23-2005 19:56:25
 Re: Antifreeze in oil-What does it do to motor? in reply to Rick Reeves, 11-23-2005 14:30:15
It looks like I posted this in the wrong section. I moved it to crawlers. Sorry about that.
buickanddeere
11-23-2005 19:31:12
If you haven't been changing the anti-freeze every few years or havn't added an additive package. The antifreeze has gone acidic and eaten holes through the sleeves. Saving money by not testing the coolant is expensive.
Russ Smart
11-23-2005 18:02:31
We ha a similar problem on a 350 many years ago and it was electrolysis eating thru the sleeve from the outside. This would probably make the engine smoke some white smoke. Otherwise it could be a bottom sleeve packing, good luck!
riverbend
11-23-2005 15:14:41
Antifreeze does not work the same as oil. It won't take the pressure in the journal bearings. Long term I have heard that a small amount will etch the bearings. The knocking and 'straining' are bad signs. It sounds like you might need new crank and rod bearings for your motor.
Johnbob
11-23-2005 15:48:54
 Re: Antifreeze in oil-What does it do to motor? in reply to riverbend, 11-23-2005 15:14:41
I have one tore down now that had anti freeze in it The bearings are eched bad,crank is O.K.The engine had a lot of sludge,but that may not be from the anti freeze.I think I would tear it down,at least pull the bearing caps.
