Homelite super xl chainsaw
colaws
02-06-2001 15:43:56
Don't want to start some stuff on this board. However I'm very fond of my Homelite saw and not very fond of my Stihl. Homelite saw is about 15 years old. In my judgement the current saws won't touch this one. Anyway,my Homelite has come up with a severe and complete fracture in its handle about where my right hand fits when cutting with saw. Fractured metal is that light alloy(?) which was widely used before plastic took over. Any of you think that JB weld or something of that sort will work to fix it?
Thanks.
Raymond Unger
04-15-2006 15:59:50
 Re: homelite super xl chainsaw in reply to colaws, 02-06-2001 15:43:56
I am looking for a MANUAL for a Homelite chainsaw. Model is XL-2. DO you know where i can aquire one?
ED
04-27-2002 17:22:05
LOOKING FOR A SET OF POINTS AND CONDENSOR FOR HOMELITE XL12. WHERE CAN I FIND THIS????
David
04-06-2002 20:50:00
Any body know the proper fuel ratio for a Homelite 16" XL.
Wm_R
04-08-2002 21:41:13
 Re: Re: homelite super xl chainsaw in reply to David, 04-06-2002 20:50:00
HOMELITE has had 3 different oils they have recommended. The old 16:1 has been discontinued and the 32:1 and EXACTMIX 50:1 in the squeeze-up bottle.
Either will work, but you have to be more careful of the exact amount with the higher ratio mix as any error is almost double = Trouble.
Also to avoid having old stale fuel mix, make the smallest amount you will use in less than a month.
Edward Sullivan
02-24-2002 07:56:56
I have a 24 inch 505 home light chain saw and it will not start as it set up for a year. I was trying to locate a Homelite dealer or someone that could repair. Please e-mail me [email protected]
serge rivard
08-06-2001 19:19:48
I have HOMELITE Super XL 130 i need to know the part price for the spoket of this chain saw please send me and e-mail to advise me and the name of the nearly distributor. Thank you sermi
BillW
02-04-2002 19:28:13
 Re: Re: homelite super xl chainsaw in reply to serge rivard, 08-06-2001 19:19:48
The HOMELITE XL 100 series share many of the same parts. I have several 'Dead' ones that I use for parts as should most older dealers. I was not aware of a 130 model. You can contact me here in KS if I can help you out with either parts or repair info. [email protected]
Michel MASSONNET
07-26-2001 07:51:36
Bonjour
Je poss�de depuis 20 ans une tronconneuse HOMELITE XL2 dont je suis tr�s satisfait.
Malheureusement la XL2 � un probl�me d'allumage.
Ou puis je me procurer des pi�ces de rechange pour cette tron�onneuse qui est une petite merveille.
Je voudrait acheter, un allumage et un guide chaine.
J'habite en France pr�s d'Angoul�me ou Poitiers ou Bordeaux.
Pouvez vous me donner des adresses de revendeurs ou ateliers de r�parations. Merci de votre r�ponse urgente.
Michel MASSONNET
John in MA
02-08-2001 22:13:53
Well, I have to agree. I have a Homelite Super XL-924 (one of the biggest they made) and it's been running strong since I paid $10 for it at a yard sale. I got a Stihl 032av at the same sale, same price, but it's been more trouble than an AR-15 to keep running. New parts here, new parts there. More more refined than the XL-924--just a headache. Of course, I can still get parts for the Stihl. No such luck on the old Homelite.
Little John
02-08-2001 02:10:02
I'm 99% sure the handle is made out of pot metal, (zinc alloy casting). Along with all the other good suggestions, you can try tightly wrapping it with raw hide. Then wet the 'hide. It'll shrink up tighter than a rust welded exhaust manifold bolt.
Aluminum casting (NT)
02-08-2001 22:14:44
 Re: Re: homelite super xl chainsaw in reply to Little John, 02-08-2001 02:10:02
alan
02-06-2001 20:24:23
Check with repair shops for dead saws for parts. A friend that used to have a repair shop found a used frame in another shop for my 360 homelite and it only costed $5. There should be some junked out saws around somplace with the right part left for you.
w. adams
07-17-2001 18:20:46
 Re: Re: homelite super xl chainsaw in reply to alan, 02-06-2001 20:24:23
wanted;-Forhomelite XL7G repair mamual.
T_Bone
02-06-2001 19:00:12
Hi colaws, I would drill the handle for small 3/16" bolts then use the JB Weld in the crack then bolt tight. Recess the bolts below handle surface.
If the handle is to badly broken then make a new one out of oak or aluminum.
T_Bone
F14
02-06-2001 18:16:17
Sounds like a tough spot to fix. Are you talking about the handle with the trigger or the top handle?
If it's the top handle, you might be able to fabricate a new one out of some thin-wall tubing or something.
If it's the 'trigger guard', best I can come up with would be to drill and tap holes above and below the break and screw a plate of some sort over it. You might could use some epoxy to reshape the handle and cover any sharp edges.
Unimog
02-06-2001 18:15:10
You might try a lawnmower repair shop, that was
a very popular saw. I believe that model is still
in production. I had the blue super xl for years
replaced it with a new one 10 years later and the
only things changed were semi-auto oiler and the
ignition to electronic. Many part saws should be around at the dealers.
ODIS
08-30-2001 09:16:57
 Re: Re: homelite super xl chainsaw in reply to Unimog, 02-06-2001 18:15:10
I AM IN NEED OF A MUFFLER FOR MY XL CHAINSAW SERIAL # 772280514 UT # 104562 CAN YOU HELP? THANKS
