There is a whole (minor) branch of engineering revolving around the relationship between torque and tension load on bolts. There is an empirically determined constant called (of all things) "the nut factor" that is a part of the equation. Torque = tension x "nut factor" x diameterAfter you study this for a while, you realized that torque specs, while better than nothing, are not a very accurate way to measure tension. (Better ways include a tensiometer, bolt stretch guauge, or a "torque-to-yield" fastern") The "nut factor" for steel-on-steel, dry threads is around 0.20. This means that 80 percent of the turning force is lost to friction, and the remaining 20% is stretching the bolt. The nut factor can vary from one bolt to the next by +/- 30 percent or so.
Any substance you put on the threads changes the average nut factor. Motor oil lowers it about 30 percent, according to the reference below. EP grease lowers it almost 50%. WD-40 may even raise it, because it is such a poor lubricant at high pressures. With loctite thread locker it is suggested to reduce torque specs by around 20%.
Permatex provides a whole table for different types of anti-sieze. Nickel based anti-sieze calls for a torque reduction of about 40%. Other types are less. See: Link
