Tool Talk Discussion Forum
Hydraulic Cylinder Source
rc_ct
11-17-2005 07:40:44
Trying to find a 2" bore single acting hydraulic cylinder. With a 6 or 8 inch stroke. Want to use it to lift logs on a roller system. Tried Nothern Tool(Lion brand) so far no luck. Tried ebay and parker hydraulics. For the cylinder configuration (In case someones interested) the fixed end I'd like a .5 inch pin (or larger) and on the extendig end I'd like a clevis or rod end bearing. Anyone have an online source for Hydraulic Cylinders? Thanks
Leland
11-18-2005 22:58:14
 Re: Hydraulic Cylinder Source in reply to rc_ct, 11-17-2005 07:40:44
find a old junk one off a p-up snow plow that they change the direction with this should work for you .
IA Roy
11-17-2005 19:55:11
Force America in Fort Dodge Iowa distributes Prince Cylinders. Good service and reasonable price. Have had next day delivery 100 miles away.
Check to see if they have the style and size you want. I got some 2 x 20's for about $110
ross in ns
11-17-2005 14:23:20
hi there just a thought i would use the double acting one if you have the source for another line if not if the logs are heavy it will come down very fast and could result in something or someone getting hurt just my 2 cents her ein canada princess auto is a great place to get stuff like that not syre if they ship to you or not check it out www.princessauto.com
Mike M
11-17-2005 11:58:44
Or if you can find a double acting one to your favor put a vent in one end and just use it single acting.
frito
11-17-2005 09:23:46
You might want to try BAILEYNET.COM. I've bought from them and they have a large selection. Good service also.
midwest redneck
11-17-2005 08:46:49
Try Yates cylinders in Saint Clair shores michigan, 586 area code.
Or search the web.
JMS/MN
11-17-2005 08:43:21
Remote cylinder from an AC WD, etc., or the lift cylinder from same tractor. Both 8 inch stroke, about 2 inches diameter. Will handle up to 3500 psi. Salvage yards should have plenty of lift cylinders.
Bob
11-17-2005 08:16:38
Have you looked HERE:
RustyFarmall
11-17-2005 12:55:33
 Re: Hydraulic Cylinder Source in reply to Bob, 11-17-2005 08:16:38
Bob, that's the one I was going to suggest. I have a brother-in-law who lives close enough to the store that he can visit regularly. He says he feels just a like a kid in a toy store at Christmas time.
rc_ct
11-17-2005 12:25:51
Thanks for all the replies one of them should have what I'm looking for. A double acting cylinder can be used as a single acting with addition of a breather cap--right?
Basically the weight of the log will be used to lower the cylinder.
JMS/MN
11-17-2005 16:53:58
 Re: Hydraulic Cylinder Source in reply to rc_ct, 11-17-2005 12:25:51
Yes-- double acting- either end: one hose, one vent. You can buy vents with screens, or make a vent with a pipe plug, hole drilled in it, install a cotter key to plug most of the hole- rest lets the air through. OK if no too dusty. Your call.
