Tool Talk Discussion Forum
Need help! Cub lowboy 154 hydraulic fluid info
LRS
11-16-2005 12:01:28
Baught an early '70's lowboy last year. Noticed that the hydraulic fluid was leaking from under the tractor.
How do I check the fluid and add the fluid? What is the recommended fluid to use?
Thanks!
LRS
LaMont Starch (LRS)
11-20-2005 12:26:04
 Re: Need help! Cub lowboy 154 hydraulic fluid inf in reply to LRS, 11-16-2005 12:01:28
Thanks for your help! Plan on trying to get at it next week.
Ken Tallman
11-17-2005 15:09:43
There are Cub and Cub Lowboy models and there are the 154 and 185 models that are a little different. The Cub and Cub Lowboy have a seperate hydraulic resavoir for hyrdaulic oil. The 154 and 185 pumps the oil from the rearend for the hydraulics and uses the same oil that is in the rearend and final drive. Hope this clears it up for you.
Ken Tallman
11-16-2005 12:27:41
The Cub Lowboy uses Hy-tran for the transmission, final drive and hydrolics.
wdtom
11-16-2005 17:34:13
 Re: Need help! Cub lowboy 154 hydraulic fluid inf in reply to Ken Tallman, 11-16-2005 12:27:41
Is the use of Hy tran fluid in all gear boxes something new, the older cub we have uses 90 weight gear oil in all but the hydraulic system?
Ken Tallman
11-16-2005 12:47:13
There is a plug on the back end of the tractor. I can't remember for sure but I think you have to remove the back cover. There should be a plug toward the top and in the middle. It will either have a recessed square or a hex. Fill it till oil runs out of the hole. Hopes this helps.
steve in in
11-17-2005 07:22:33
 Re: Need help! Cub lowboy 154 hydraulic fluid inf in reply to Ken Tallman, 11-16-2005 12:47:13
Ken has it. Check the boot on the shifter. Mine leaked pretty good there. Taking the fenders and the rear cover off isn't too bad of a job.
I kinda miss my 185. It sat high enough not to get the blowout all over me when I mowed, unlike my dixie chopper.
LRS
11-22-2005 19:01:45
 Re: Need help! Cub lowboy 154 hydraulic fluid inf in reply to steve in in, 11-17-2005 07:22:33
Hope you can still help me out. Took a look at it yesterday. Looking att he tractor from the rear there are two plugs, one one each side, both about the level of the rear axel.
Are these the proper ones? I removed the left one and fluid came out, removed the right one and nothing came out. Does this mean anything to you guys?
Thanks
Ken Tallman
11-23-2005 19:33:14
 Re: Need help! Cub lowboy 154 hydraulic fluid inf in reply to LRS, 11-22-2005 19:01:45
You have to take the rear cover off. If you have the the mower on you have to take the pto pulley off. Then there are a few bolts to remove. Not hard to do.
Ken Tallman
11-23-2005 19:33:01
Ken Tallman
11-23-2005 19:39:00
 Re: Need help! Cub lowboy 154 hydraulic fluid inf in reply to Ken Tallman, 11-23-2005 19:33:01
After you remove the rear cover you will find another plug like the other two you found. I believe it may fill the lower end also. If not fill all of them till it runs out of the fill hole.
