Tool Talk Discussion Forum
40x64 Pole Building
Glenn F.
11-16-2005 06:38:52
I'd kinda like to put up a 40x60 pole building, with probably 10' side walls to house my tractors, trailers, etc. Just a cold storage shed. I now have adequate shop space but not enough storage. My tractors and trailer have to winter at my brother's place and I'm never sure when that arrangement may come to an end. I know there are many options, but I figure just one sliding door, a service door, a few light bulbs, no overhangs, standard white steel, and crush rock floor. What would a basic shed like this cost if I constructed it myself? Is dismantling and reconstructing a used shed an option, assuming I could find one very cheap? Thanks, Glenn F.
Glenn F.
11-17-2005 06:41:47
 Re: 40x64 Pole Building in reply to Glenn F., 11-16-2005 06:38:52
Thank you guys. I see I still have more homework to do....Plenty of time! GlennF.
BobMo
11-16-2005 18:55:37
Glenn, I just had one put up 3 years ago 40x60x12 with 60x15 (4) bay shed on one side erected for 12 1/2 thousand. Unpainted 26 ga. galvanized. Purchased from BCI in Oklahoma who also sent erectors. Barn erectors work by the job not the hour.
I don't think you want to tackle this for what they charge for erection. They are professional and will be done in 2 days on your level site. This get not include any wiring which I did myself but did include (1) 36" door and (1) rolling 10' door. In retrospect I wish I had gotten (2) rolling doors and I think for the minor added cost you'll regret it if you don't.
Good luck whatever you decide.
dennis in OR
11-16-2005 17:21:42
before i left NC,I put up a metal carport 25x30 offseason 995. they put it up!! on slab i already had for sons basketball court.closed in the sides front and back myself with the same kind and colar metal 25oo for it all . next year i am going to add another 40x30 to make it a 65x30
Led
11-16-2005 16:47:41
Have you considered limestone (type spread on field) rather than rock for the shed floor ? Cheaper, easier to level & compacks with water.
Just an idea.
Led
loko17
11-16-2005 13:42:40
A few years ago, I had a 42' X 60' X 14' pole building put up by a local contractor for $25,000.00. It has 3 12'X 14' sliding doors and a standard entrance door, gutters, plus 2' soffits on front and back. Roof has a 4" on 12" pitch. Floor is crusher run (gravel and dust) and I ran a 100 amp sub panel from my other pole building (my shop) for electic power (recepticles and lights) which I wired myself for probably around another $200.00. Could have done the whole thing myself, probably saved a few bucks but I'd probably still be working on it. This way it was done from start to finish in about three weeks. Never been sorry for doing it the way I did. Good luck!
TRC
11-17-2005 08:24:33
 Re: 40x64 Pole Building in reply to loko17, 11-16-2005 13:42:40
Two years ago I had a 40'X60'X12' built with concrete floors, 4 large garage doors, a 36" service door, 3 windows and a large skylight down the middle for lighting. I also got insulation and gutters/downspouts all for $25,000 from a local contractor. They did excellent work and were done in about 2 days (they hustled all day long for those days). If I had tried to build it the job wouldn't have been done as well and I would still be working on it. It's the best money I ever spent. I would check around thoroughly before starting the project.
Tim
thepinkpanther
11-16-2005 13:42:40
i just got my bid back today from the mennenites. a 30 by 60.12 ft side walls.two open 15 ft bays.two bays framed for sliding doors.both ends enclosed.$10,650 sheeted with their metal.
$7050.00 sheeted with new metal i already have. i told them go ahead with my metal.i had bought it already to build a big combine shed.then i sold my combine.
.barry
TimWafer
11-16-2005 13:20:20
I built a 40 x 80 last year for about $35000. It did have a few extras. Like a 1� overhang all around and a 6/12 pitch with 14� sides and one 12 x 12 overhead and a service door. Also laminated plastic sleeved posts. I did all the excavation work myself (there was a lot since it was built on a side hill during the wettest summer ever!) and half or better of the construction.
Tim
Glenn F.
11-16-2005 06:42:29
I'm thinking 64' long as my trusses would likely be spaced 8'. I live in Green Bay, WI. Sheds around here are generally 3-12 roof pitch. Glenn F.
dhilbert
11-16-2005 12:48:46
 Re: 40x64 Pole Building in reply to Glenn F., 11-16-2005 06:42:29
Glenn, you say you are in Green Bay, I am in Depere, See you posting alot about DC's and such. We should sit down and swap stories, my dad has the 41 DC my grandfather bought new after the war, been rebuilt 4 times that I remember. Needs it again, just lookin for time to get it done. Anyway just wanted to say hi. Dan
Rauville
11-16-2005 07:19:05
The last building that we had built was last year. A 50 x 36 x 12, with fill, 100 amp electrical system came to just under $7 / sq. ft. The building is just the basic "lumberyard" model, no frills.
I'm sure by now, steel / lumber prices have increased the cost.
