Tool Talk Discussion Forum
Trailer Pole Length
Glenn F.
11-14-2005 12:49:11
Today is my day for misc. questions I guess. The pole on my 12,000# trailer is 55" long. I happened to measure one on another 12'000# trailer and it was 69" long. Other than the difference in response time while steering it while backing, what would be the effect of a shorter/longer pole, especially while driving down the road? Thanks, Glenn F.
wdtom
11-15-2005 16:44:16
 Re: Trailer Pole Length in reply to Glenn F., 11-14-2005 12:49:11
The longer the pole length, the longer the lever the tow vehicle has, which makes it more difficult for the trailer to "wag the dog".
Glenn F.
11-16-2005 04:58:25
 Re: Trailer Pole Length in reply to wdtom, 11-15-2005 16:44:16
Yea Tom, I was wondering about that. When I hauled my tractors last Sunday, while going downhill with the DC on, the trailer began to sway. It was a little scary. When I unloaded it I determined there was very little tongue weight. I hope more tongue weight makes it tow better. I suppose I could lengthen the pole a foot, but I'm hoping to avoid that. Glenn F.
wdtom
11-16-2005 17:42:54
 Re: Trailer Pole Length in reply to Glenn F., 11-16-2005 04:58:25
while not being super experienced at towing, too little tongue weight is not good and can cause what you describe. Appling the trailer brakes can help to control it, but not getting into a swaying situation is better. How about your tow vehicle, tires up to pressure, springs good? There was a few posts on another list, maybe Tractor Talk or the Allis Chalmers about tongue weight and how to guesstimate it. Mostly they settled on hooking up the trailer and checking the bumper height then loading until the bumper dropped 2". Not a bad idea, might need to be fine tuned to suit the vehicle and springs etc.
wdtom
11-16-2005 17:44:45
 Re: Trailer Pole Length in reply to wdtom, 11-16-2005 17:42:54
Heh heh, just drop down a few posts right here and there it is, trailer loading.
Slowpoke
11-15-2005 00:47:36
You may notice on some of the tractors hauling two trailers that the tow pole is in the neighborhood of 8' long on the second trailer. The tires on the first trailer kind of squish the road surface ahead of them as they roll along. The second trailer is set back to allow time for the road surface to settle back down. It's all designed to extend the life of the road. It's used on gasoline tank trucks that tow a tank trailer, sand/dirt haulers with two trailers, and others. At least in the Golden State. I think your pole length is up to the trailer designer.
