Tool Talk Discussion Forum
Aluminum service
pjw
11-13-2005 05:16:27
I have aluminum wire coming into the house. All circuits are copper. How do I know if my panel connections at the main are rated for aluminum? Is there a way to tell if a problem is coming?
dr.sportster
11-13-2005 05:29:36
 Re: Aluminum service in reply to pjw, 11-13-2005 05:16:27
All service entrance cable is aluminum.Heat is resistance, if your lugs are not hot there is a good connection.Hire a guy with an infared camera or shut off the power[pull the meter] and feel it.If you have Penetrox on the connections then you should have nothing to worry about.The lugs are rated CU/AL in most panels.I think you read the other guys post and started to worry.
to mister potato head
11-14-2005 16:51:35
 Re: Aluminum service in reply to dr.sportster, 11-13-2005 05:29:36
Not all service conductors are alum.If came from my company it would be cu.
dr.sportster
11-15-2005 07:54:10
 Re: Aluminum service in reply to to mister potato head , 11-14-2005 16:51:35
I said service entrance cable,not service conductors.Have you ever seen copper service entrance cable where the nuetral is wrapped around the other conductors? I have never seen it but that does not mean it isnt made.All Ive ever seen is al.I will say I have never seen an electrical engineer that specifies aluminum.They like copper.
Dusty
11-15-2005 08:13:15
 Re: Aluminum service in reply to dr.sportster, 11-15-2005 07:54:10
There is a service entrance cable (SE) that is copper with the netural wraped around the out side, the wire is usually tinned. Never knew why it is tinned.
Dusty
dr.sportster
11-15-2005 11:21:55
 Re: Aluminum service in reply to Dusty, 11-15-2005 08:13:15
So there is copper.Not popular in my area.It must be tinned so it does not turn green by the service head,maybe.
mace56
11-13-2005 08:59:38
If you buy service entrance cable it is all Aluminum and has been for a long time so most boxes and large breakers are OK with it.
Neighbor is electrician and he helped me with my garage connections. He said the bad connection develops over long time due to difference between Aluminum and other metals in the box. They have a paste to use to prevent. I would still recheck after a few months or even a year. Seems like I have all my breaker panels open that often anyway.
I had to use wire lugs to tie my Aluminum to copper wire at a junction box. I have not used paste but I am going to upgrade to a larger cable and service box in a few months.
