I believe Charles has you in the right direction here. It is common to _not_ count the bare or green whire when talking about a wire run, so it sounds like you actually have a 10-2 with ground wire that you are using? A 10-3 wire with ground would have white for nuetral, black for hot, red for the other hot, as well as the bare or green ground wire. Kinda confusing, when they don't count a wire that you see there, isn't it? :) The nuetral, or white, wire is not used on a true 220v deal - you only need the 2 hots - red & black wires plus the always needed green or bare ground wire. Some 220v devices end up using 110v plus one of the hot wires for controls such as a timer, light bulb, etc. A clothes drier or electric stove come to mind - they need all 4 wires to make everything work right - but your compressor does not have anything like that, so no need for the white nuetral wire. The white wire can be used if you properly marke both ends with a red dye or red tape to let others know what you did - turned it into a current-carrying hot wire. Hope this simple dirt farmer can explain it a bit without confusing..... Just do what Charles said, & it should work for you. --->Paul
