Tool Talk Discussion Forum
Hand Tire Pump
Dave in GA
11-10-2005 15:26:22
When I was a kid, my father had a hand tire pump that was heavy duty and was almost all steel, including the cylinder and handle. The hose didn't have one of those flip-lever devices but instead had a screw-on fitting that you would simply screw onto the valve stem. The pump was a workhorse and did great for many years until the rubber piece around the piston finally disintegrated.
Now all the hand pumps I see are cheap plastic and Chinese-built, and they have those weak hoses with the flip levers that lock onto the valve stems. I bought one at Harbor Freight and the whimpy hose split open the second time I used it, and I was only putting 10 pounds of air into a riding mower tire! I've been searching around for a decent quality, metal tire pump and haven't found anything much better than the Harbor Freight one. Is there a well-built tire pump to be found anywhere?
Slowpoke
11-17-2005 00:23:10
 Re: Hand Tire Pump in reply to Dave in GA, 11-10-2005 15:26:22
I needed a new hose for an old pump and was unable to find anything decent at auto supply, etc. I was at Loews and found 3/16 fuel line rated at 50 psi. I bought 3' and used screw clamps with the original air chuck and at the pump outlet, and it works fine. Don't forget there's a ball bearing in the bottom of the pump outlet.
BigMarv1085 in Ga.
11-11-2005 03:55:47
I have used one of the Campbell Hausfield pumps. It works fair. I live in Williamson, Ga.
Charles (in GA)
11-11-2005 06:08:15
 Re: Hand Tire Pump in reply to BigMarv1085 in Ga., 11-11-2005 03:55:47
Just a little way east of me. I pass thru Williamson coming and going to Griffin, to the New Holland Dealer. We now have a NH dealer in Newnan, but the folks at Wade NH are so sharp on parts I prefer to use them. Besides, lots of neat stuff to look at each visit.
Charles
ebbsspeed
11-10-2005 19:26:24
Here's one that still has the leather cup inside. Good quality for less than $60
http://www.h2orocket.com/topic/pump/pump.html
Ralph - Ohio
11-10-2005 17:25:54
Gemplers at Gemplers.com has a heavy duty hand pump for around $50 but I can't tell what type of fitting it has.
RayP(MI)
11-10-2005 16:58:07
Have you thought of looking at flea markets and garage sales? You might be able to pick up an old one and replace rubber parts, and be in business. By the way, tha one we had had a leather cup for the seal on the piston. You could replace it with a piece of leather from an old shoe or something like that. Might have to oil the leather liberally, until it takes shape.
Charles (in GA)
11-10-2005 15:51:16
Where in Jawja are you located, Dave?
I'm in Luthersville, south of ATL about 50 mi.
Charles
Dave in GA
11-10-2005 15:58:45
 Re: Hand Tire Pump in reply to Charles (in GA), 11-10-2005 15:51:16
Thanks for the info Charles. I'm in Lawrenceville, NE of Atlanta. There's a big gas and steam tractor/engine show this Friday and Saturday in Cumming.
Charles (in GA)
11-10-2005 15:44:54
This is a foot pump, not a hand pump, but made of metal and pretty neat sounding, from J C Whitney of all places.
Charles
Charles (in GA)
11-10-2005 15:46:06
 Re: Hand Tire Pump in reply to Charles (in GA), 11-10-2005 15:44:54
Another foot pump, this one is a Campbell Hausfeld. for less than $5!!!
Charles
Charles (in GA)
11-10-2005 15:49:33
 Re: Hand Tire Pump in reply to Charles (in GA), 11-10-2005 15:46:06
A hand pump, aluminum body, real nice, but pricey at $100. From Amazon.com
