Tool Talk Discussion Forum
Light duty shredder/chipper
Bus Driver
11-10-2005 11:38:11
This question is not exactly suited to any forum here, but hopefully you can help me. I have never used one of these. What type cutters do they have. Is it like shaper knives or like hammers in a feed grinder? What maintenance is required to the cutters and is it expensive? I have some stable manure mixed in with lots of straw that I need broken into bits about 1/4" diameter. The area where it is to be spread cannot be tilled or plowed. Can this stuff be put through a shredder? Any suggestions on breaking down this manure?
Arizona Bob
11-11-2005 08:51:06
 Re: Light duty shredder/chipper in reply to Bus Driver, 11-10-2005 11:38:11
Bus Driver,
I have put dried manure through the shredder end of my 8 hp chipper/shredder. Emphasis on Dried. Removed the screen which helps. So, Yes, it can be done. Bigger question is whether its worth the time and trouble.
I"ve got a couple of horses and lots of leaves and branches to be chipped. When I put a compost pile together I pile all the ingredient about a foot deep and work it with a roto tiller. Might be an alternative for you.
Bob
T_Bone
11-10-2005 20:22:58
Hi BD,
I have a 8hp chipper/shredder and it won't do hard manure. It does really good on wheat straw and limbs upto 1" or just what I bought it for, garden waste.
Compost the manure is the best way. Takes about 30 to 60days start to finish but is pretty hot (high in nitrogen) for fresh garden use but is usable as a side dress at 30days if you don't get it on the green of the plant.
Compost mix:
2/3 greens, (manure of any type) or most green plants
1/3 browns, (wheat straw, wood chips, leafs, etc:)
Enough water that when you make a fist ball it will lightly drip excess water.
I put down a layer of straw then cover with a light coat of wood chips then a heavy layer of manure then water then repeat until I have a 4ft high pile then water every day for 5min. Were so dry here in AZ that I have to water each day, but you may not have too.
Using the method above my compost will be ready in about 45days. If I don't want the compost so hot then I have to wait for about 90days. The compost will look like damp earth when done that crumbles in your hand.
If the compost smells bad after a couple days then you have a ingredient wrong, most likely not enough browns or too wet. If that happens add more browns.
I've never had a compost pile smell using the above method.
T_Bone
JT
11-10-2005 15:38:28
I do believe you will be dissappointed in any chiper for doing what you want to do. They use a screen in the bottom to hold the debri in untill the hammers beat it to the size of the holes in the screen, then it has to fall out the holes. If this stuff has ANY moisture at all, it will probably clog the screen, then you will loose your patience.
Robert in W. Mi.
11-10-2005 15:04:08
Unless it's completely dry, it will give you fits trying to get it through a shredder.
I've owned 4 different ones, and unless you spending a "pile" of $$ for a big one, they aren't worth owning.
Why not move this stuff with a loader to where it can be "rotavated" into what ever size you want???
Robert
supergrumpy
11-10-2005 12:51:20
I had Woods pto chipper
chute for branches used some heavy knives spinning on face of a rotor
top hopper kinda chopper had bunch of short metal cutters hanging loose on some brackets, these guys did the job, had to make sure they didn't take your arm in, not good for stuff over 2 inches
stuff came out the bottom, had to keep moving it to keep it from plugging
Charles (in GA)
11-10-2005 12:50:10
Don't know about the current crop of chipper shredder units. A neighbor lady had a older (late '80's) Troy built unit. As a chipper of limbs, it wasn't worth anything. It did have a "flywheel" type cutter and a special chute for limbs but only rated for one inch or less.
I didn't try to use it to make mulch from leaves, etc, but it had several rows of hammers in it and several different "screens" which were curved steel plates that fit on the bottom with different sized holes. I can see how it would probably work OK to make mulch with leaves, probably would work for what you want to do, but I do not have any pactical experience with it. It constantly ate belts according to the owner and after getting the engine running, I simply advised her to sell it, as she has no real use for it. It was something her father had purchased for way too much money.
Charles
