Tool Talk Discussion Forum
Bolt/stud grade 8
Jerry L /AZ
11-09-2005 15:57:38
I need to make up some studs 5/8-18x9" I cant find any grade 8 only grade 7 and then only in 3' lengths. I'm mounting some wheel weights about 223lbs each. two weights per wheel or 446 lbs total takes three studs per weight would a grade 7 be ok to use? thanks for you thoughts Jer
wdtom
11-09-2005 17:40:42
 Re: Bolt/stud grade 8 in reply to Jerry L /AZ, 11-09-2005 15:57:38
If you were talking 4000lbs. well maybe you would need 3 grade 8 studs per wheel. But 400lbs, any soft common threaded rodwill hold them fine. You just aren't talking that much. As long as they are tight enough to keep them from moving they are OK, and this won't take all that much.
Jerry L /AZ
11-10-2005 05:31:31
 Re: Bolt/stud grade 8 in reply to wdtom, 11-09-2005 17:40:42
thanks for your thoughts on this. gives me a better idea on how to do this. wish I could get a set of pie weights but the BOSS says I Have to do with what I have. oh well. was looking at McMaster-Carr for some stand offs but they only listed up to 1/2" if I had a lathe I could make them but again (if) is another subject. have a great day and thanks for the info. Jer
BobMo
11-09-2005 17:22:54
You just asked Allen what you should do on this and now it sounds like you've made up your mind. What you need to do is a search for the physical properties of both grades and make up your own mind.
Check McMaster Carrs' web site and see if they don't have the grade you need in the length you want or all thread you can cut to length. Be sure you use the same grade nuts and washers. Good luck..
Jerry L /AZ
11-09-2005 19:37:44
 Re: Bolt/stud grade 8 in reply to BobMo, 11-09-2005 17:22:54
Well BobMo yes I asked Allan on his thoughts because I valued his opinion as he has worked with wheels and such. I checked McMaster Carr and they did not give the properties of or between the different grades that I was hopeing to find out here. just looking for the safest way to go but Thanks for your comment. Have a great evening Jer
Ol Chief
11-10-2005 00:50:27
 Re: Bolt/stud grade 8 in reply to Jerry L /AZ, 11-09-2005 19:37:44
Hi-tensile stud stock grade # B7 should be available in 6 ft. and 12 ft.lengths from most any mine and mill supply or fastener supply company.This grade is commonly used in industry using high pressure and temperature piping systems for flange bolting with very high loads. Nuts for use with this service are grade H2.Both are high alloy material and are rust resistant to some extent.I do not remember the spec.on these items but anyone here in possesion of an MACHINERYS HANDBOOK can look up the data.Sorry,my book is at present not within my reach.
Jerry L /AZ
11-10-2005 05:15:11
 Re: Bolt/stud grade 8 in reply to Ol Chief, 11-10-2005 00:50:27
hey thats the stuff I needed to know. I do not have the Book and do not use the information very often. Thanks for the information. have a great day there ol Chief thanks again..... Jer
