Tool Talk Discussion Forum
Walking on steel pole barn roofs
Dog's Friend
11-09-2005 06:56:57
I have a handyman company and one of my customers wants me to powerwash the roof of her pole barn. The barn is 40'x60' with 15' sidewalls and a moderate pitch roof. The roof is white corrugated steel that has mold growing on it from shade trees nearby. The roof peak is made of opaque fiberglass to let the light in the barn. The structure is about 20 years old.
I can reach about 8'from the edge working from a ladder, but can't reach anywhere near the peak. I hesitate to lay a ladder on the roof to stand on because I don't want to break the fiberglass peak.
I am 6'1" and 250lbs and nervous about denting the roof metal.
Any suggestions? She is a good customer and I hate to walk away from a challenge.
Mark - IN.
11-13-2005 01:10:28
 Re: Walking on steel pole barn roofs in reply to Dog's Friend, 11-09-2005 06:56:57
I'm about your size. I learned my lesson up on mine, pretty much the same dimensions. I wasn't using water either, just fastening down the corregated roof. As long as the sun was on it, I had good grip from my boots. But when the sun started going down and it was cooling, began losing my boot grip standing on the screws for grip. It hurt when I slipped and hit the roof, it hurt worse when I slid off and hit the ground. Didn't break anything, but it sure did hurt. Am glad nothing like a tractor or fence post was where I landed, because there often is. Just be careful.
Mark
deanop
11-11-2005 01:34:43
one other thing i remember from working/walking on roof..you might want to have "just roof shoes", while your working on it...i know when i was building my pole shed, i'd could walk on the tin with plenty of traction, but if i got sand on my boots, it made things alot slippier spel. be careful up there..
TomTX
11-10-2005 03:56:24
You bid less than $200 to pressure washer clean a 40 by 60 roof with 15 ft sidewalls? How do you stay in business?
Stan in Oly, WA
11-09-2005 18:06:48
Hi, D F
If you're like me, you already bid the job at a price that didn't account for the rental of an expensive piece of equipment, and since it's a good customer you hate to go back and admit that your options are down to not breaking even if you use a lift, or doing all right without one unless you fall off and die.
The only roof I ever fell off was a low pitch shake roof that I was pressure washing. It got slick quick. I never thought I'd get hurt, just like I never thought I'd get hurt any other time I got hurt, so I didn't go into too much detail about the knot on the rope that I was on the other end of. When I saw my feet go up in front of me, I hardly had time to get my hopes up about that rope stopping me, but on the bright side, when it didn't I hardly had any time to be disappointed before I hit the pavement.
Since then I've put a metal roof on a house and had a light rain start falling while I was on it working on a flashing. I'd estimate it was every bit as slippery as that shake roof.
My advice would be not to do anything that seemed like it might be okay if everything went just right. What you ought to aim for, IMHO, is a plan where you'll still be all right if every single thing goes wrong. Being poor but alive is the better alternative.
All the best, Stan
MarkB_MI
11-09-2005 18:06:45
Is it corrugated steel (e.g. "Strongbarn"), or is it actually steel siding like you'd get in a polebarn kit? Strongbarn is pretty tough, you don't need to worry about walking on it. If it's commercial steel siding, just be careful to avoid stepping on the ridges. As long as you step in the valleys you won't damage it. Try to step on the screws whenever possible so your weight is supported by the purlins. Also, you can throw a couple of 2x6s in the valley to support your weight if you don't feel comfortable standing on the steel. The boards will be less slippery than the steel, and the roofing screws should keep the boards from sliding.
Definitely rig up a arresting harness; you don't want to fall off a 15' side wall. And you really don't want to slide all the way down the roof, then go over the side.
Bernie in MA
11-09-2005 14:35:10
I/we just finished roofing a shed with aluminum that has a pitch 4" to the foot. My son-in-law walked on it wearing rubber boots, making sure to walk on the nails, thereby being over the purlins and not denting the aluminum. HTH
thejdman01
11-09-2005 14:15:52
try local rental company get a lift safe and fast can move fairly far w/o moving hte machine with th boom
Kevin (FL)
11-09-2005 10:49:59
For better traction on the roof, take a section of inner tube and wrap/tie around your shoes. Tie a safety line (1/2" or bigger) to a "dead-man" on one side of the barn and then toss it over toward the side you'll be coming up. Use this when you go up the roof the first time until you know how your traction is. With the roof dry, go up towards the peak and see if the fiberglass panels are screwed in place. Remove two or more sections as needed and then access the roof from inside using a lift or whatever will fit inside the barn. Not sure about the ridge cap though--it might get in the way of removing the peak panels. The bucket truck idea should work too but you'll be doing a lot of moving around to cover the whole roof.
eric johnson
11-09-2005 10:44:54
my uncle is 6' 2'' tall at least 200 pounds and he was waling on the roof of his pole barn just don't step on the sky lights or like it was said get a bucket truck but you will be ok
by the way do you have a ladder that has hooks to hook onto the peak if you do and use it you will be fine
Jay (ND)
11-09-2005 10:20:39
Holy crap - be careful. Ever been on one of those roofs when wet? I have. I would sooner be on hill covered with oiled plastic. It's slippery stuff.
wyokid
11-09-2005 08:11:23
Northern tool has extensions for power washers.
Jack-Iowa
11-09-2005 07:53:03
all else fails get a bucket truck , should have no problem doing that.
Dog's Friend
11-10-2005 03:45:20
 Re: Walking on steel pole barn roofs in reply to Jack-Iowa, 11-09-2005 07:53:03
Thanks guys for some great info.
Unfortunately a bucket truck is not feasible. There is a fenceline with a real thick briar patch that runs right up to the wall along one side.
I looked at Northern Tool and found a 24ft extension and a surface cleaner that should do the trick and I can work from the ladder. The whole get up will cost about $200, which is more then I bid the job for. But then I'll have it for other projects down the line.
We'll see, I'm in Wisconsin and it's getting too cold to be playing with water outside. Might put this off till spring.
Thanks again
-Dog's Friend
