Tool Talk Discussion Forum
Need New Compressor Tank
TwinCreek
11-09-2005 04:27:12
My air compressor tank has just failed. Where can you economically get a replacement tank? My tank appear to be a 30 or 40 gallon tank. I like the compressor which is why I want to get just the tank. Thanks.
FarmerDave
11-10-2005 15:06:25
 Re: Need New Compressor Tank in reply to TwinCreek, 11-09-2005 04:27:12
Your cheapest dollar outlay would be for a used tank that had burned up its compressor.
Little Ed
11-09-2005 05:41:03
I took two 100 pound propane tanks, stood them upright, took a piece of 12 gauge hot rolled and cut holes in it to fit over the bosses where the caps go, cut the threaded portion off of the caps (to use them like a nut and tightened them down with a chisel). The 12 gauge was also formed into a U shape, so that I could cut the compressor and motor platform from the old tank and bolt it to the new fabrication. I should mention that I figured out the plumbing first, as that determined the distance apart that the tanks would be. (put a union in the line between the tanks) Now that I try to describe it, I guess that it took a fair amount of fabrication. Didn"t seem like that much work at the time. Ed
Vern-MI
11-09-2005 05:05:50
try surplus center
Bus Driver
11-09-2005 04:30:52
Grainger may not be the lowest priced source, but they do have good selection of readily-available tanks.
