NC Wayne
11-07-2005 22:12:44
Re: Woodburning Fireplace Inserts in reply to Keepin Warm, 11-07-2005 18:29:10
I bought a used Appalachian insert a few years back. I had to sand blasted it to remove some surface rust because it had been setting outside for several months but once it was clean, reblacked and resealed you couldn't tell it from a new one. It's a really nice looking unit with a three speed, thermostatic controlled fan hidden underneath the firebox, a good sized ash drawer, as well as a heavy cast door with a nice size brass framed window in it. As for the main part of the stove and it's built out of good heavy material also. I had planned to build one myself but the steel alone was gonna cost over $200 plus the cost of a blower motor, the glass for the door, etc. I lucked out and didn't have to give but $200 for it and with what I did to get it ready to use didn't have but maybe another $50 in it so I was really happy with the way things turned out. The only thing I did to it that the factory hadn't was to line the bottom of the firebox with the 1" thick firebrick since the fire is built directly on it and not on any type of grate. Besides protecting the bottom of the firebox it also holds the heat pretty good so the blower doesn't shut off as quick if the fire does happen to die down. It has the catalytic elements which are really nice. Once I get a good fire going I can usually close the damper all the way and let everything exhaust through the elements and get the maximum efficiency out of it. I'm using it to heat a 1800 sq ft house and it usually keeps the temp between 70 and 75 even on the coldest days which here in NC is usually around freezing or a little below. With good, dry wood I can usually load it with two or three pieces when I get home from work around 6 and then throw on another 2 or three before I go to bed and it's still going when I get up. Do the same thing and throw on another piece or two before I head out to work and it's still got a good bed of coals when I get home. Unless I purposefully let it die out I can light it once and keep it going all winter long with no problems, all I've got to do is rake out a little ash once a day. The nice thing about the elements is they do allow you to burn a smaller, more fuel/wood efficient fire than you could without them. The hard part, especially if your used to a fireplace, is learning not to over fuel it and learning to just let it alone once you do get it going. With a fireplace you have to pretty much have a roaring blaze going to get any heat since so much of it goes straight up the flue. With the insert a small smoldering fire will throw off ALOT of heat and since you can catch 90+ percent of it it simply takes less wood to get the same results. I've found if I get it going and then simply let it alone I wind up with 99 percent fine ash and a few clinkers, but if I mess with it too much the percentage reverses. The at the end of the winter before I got my insert my propane bill was over $400 to top off the tank, at the end of the first winter I had it it cost me $70, and most of that was cooking and drying cloths since both my oven/stove and dryer are gas. Check into an Appalachian. I'm a stickler for liking heavy, well build stuff and I have absolutely no complaints about mine.
