Air Compressor
John McCarter
11-23-1998 03:34:49
Just upgraded to a new, larger air compressor. I have a heated shop and an underground air line running to an unheated shed. Thought of putting the compressor out there to eliminate the noise. But what's the pros or cons of having it where temperatures may be at 10 deg or less? Any advice will be appreciated, thanks.
John from Pa.
11-25-1998 16:47:57
 Re: Air Compressor in reply to John McCarter, 11-23-1998 03:34:49
Thanks to all who responded. The new 7-1/2 hp compressor is installed in the heated shop and isn't much noisier than the old 1-1/2 hp.
: Just upgraded to a new, larger air compressor. I have a heated shop and an underground air line running to an unheated shed. Thought of putting the compressor out there to eliminate the noise. But what's the pros or cons of having it where temperatures may be at 10 deg or less? Any advice will be appreciated, thanks.
JK MN
11-24-1998 10:50:32
John, How much are you going to use it? You could possibly put one of those crankcase magnetic heaters or one of those electric battery heater wraps on the compressor, and maybe with a timer, to turn it on an hour or so before you turn on the compressor. The only other concern, like other posts, is the extra condensation that can form.
Bob
11-23-1998 15:23:41
You may also get more condensation in your tank and lines causing damage to any tools you may use.
Bob
11-23-1998 15:21:23
JimC
11-23-1998 15:21:13
I did the same thing, my compressor is located outside my shop
to eliminate some of the noise. My air lines run above ground, to the ceiling in the shop, I would have to wonder if yours would freeze being underground. My compressor starts in the really cold, (about zero degrees F)
but it does groan and moan, and I'm sure its not all that good
for it, so I only use it when its absolutly necessary.
Good Luck
PV=NRT
11-23-1998 14:50:06
PV=NRT is the equasion that determines the pressure in your air compressor tank(for an ideal gas which is "almost" air). If the temp goes down your compressor will increase the "N" by compressing more air into the tank. So the pressure does not change. And they said I would never use that stuff I learned in Physical Chemistry class in college 20 years ago!!
I would worry about the compressor starting at 10 degrees. It could break the compressor due to cold oil. Heat pumps have heaters in the compressor to eliminate cold starts. I wouldn't start a compressor that was below 40 degrees F.
Thats my 02C. :)
jake from il
11-23-1998 10:03:21
pressure is affected by tempeture
