Tool Talk Discussion Forum
which extra cab truck
dieselade
11-07-2005 03:55:21
not talking about crewcab truck, just the extra cab truck...which of the big three has the most room in the back seat area. chevy looks like it has the biggest entry door. my older ford extra cab is a little cramped and entry to the rear seat is difficult.
buickanddeere
11-08-2005 01:56:34
 Re: which extra cab truck in reply to dieselade, 11-07-2005 03:55:21
After going to four full sized doors. I'll never consider an "extended cab" pickup again.
petetx
11-07-2005 07:15:16
DODGE I have had all 3 ford gmc & dodge Dodge beats them all any way you stack em.
Jonfarmer
11-07-2005 07:14:25
Yeah I'd say Dodge has the biggest cab. They just came out with a mega cab which has already been mentioned, designed to have as much leg room at the front seats, and the rear seats recline. Dodge also has a really good diesel, but I'm unsure weither Cummins is better than a Duramax. Dodge always has boasted about having the biggest cabs. I just wonder when they are going to start building larger trucks again, biggest they make right now is a one ton.
Mike M
11-07-2005 04:54:05
Dodge hands down ! They are even bringing out somekinda mega cab,an extended crew cab.
Galen
11-08-2005 05:04:22
 Re: which extra cab truck in reply to Mike M, 11-07-2005 04:54:05
Ford has had this cab - crew cab with an extended cab behind it - since the 70's They called it the "Long Ranger". Sold a bunch of them to cattle men. Dodge had a smattering of them in the late 80's and early 90's, but VERY rare. You can still special order one from Ford.
Glenn F.
11-07-2005 05:08:42
What's the difference between crew cab and club cab? Glenn F.
Mike M
11-07-2005 06:31:23
 Re: which extra cab truck in reply to Glenn F., 11-07-2005 05:08:42
I think a crew cab is to have 4 full sized normal opening doors and the club/extended cabs either have no doors back there or newer ones have a door or 2 you can open after the front door/s are opened.
Glenn F.
11-07-2005 08:24:12
 Re: which extra cab truck in reply to Mike M, 11-07-2005 06:31:23
Thanks. I kinda figured Crew cab was for the "work crew", implying 4 full seze doors. Glenn F.
jd9295
11-08-2005 21:27:40
 Re: which extra cab truck in reply to Glenn F., 11-07-2005 08:24:12
Get the Dodge with the cummins and the six speed and it'll still be going when you cant drive anymore.
Ive got a 3/4 ton dodge and a 1 ton ford, both diesels and the dodge will outpull the ford any day with any load. Matter of fact the dodge has 205,000+ and havent spent a dime other than normal maint. Ford has been in the shop so much im not sure what color it is any more. It most likely will be sitting on a dodge dealers used lot real soon
