Tool Talk Discussion Forum
Gasket remover
John/Pa
11-06-2005 17:40:33
What gasket remover do you like to use? What works best on old gaskets that are really stuck fast. Need to remove gaskets from aluminum blower housing. Tried wire wheel but was slow going and was eating away aluminum around bolt holes.
Bud in NC
11-08-2005 04:44:27
 Re: Gasket remover in reply to John/Pa, 11-06-2005 17:40:33
We used to use "Chisel" brand gasket remover on turbine related equipment - it's NOT skin friendly!!!! As a back up, try Arm & Hammer Oven Cleaner. Supposed to be the same stuff but nat as strong. I don't know what it'd do to alumium, though.
hay
11-07-2005 03:37:36
use a die grinder 'cookie'. get them from wally=mart or any route sales tool truck.
dr.sportster
11-06-2005 18:35:03
On aluminum crankcases I make a scraper out of aluminum flat stock.This way I can scrape as hard as needed to get the gasket off but no aluminum gets scraped off.I sharpen it on the belt sander.
the tractor vet
11-06-2005 17:57:12
I am old fashioned it is called a good sharp gskt scraper and when i am done with it i use a scotch brite discon a rightangel grinder and when doing alu. i use the disc for alu. as far as the spray stuff they say NOT to use it on alu.
John/Pa
11-07-2005 02:51:27
 Re: Gasket remover in reply to the tractor vet, 11-06-2005 17:57:12
I know not to use chlorinated products on aluminum, didn't know about not using anything else. I was trying the old putty knife but I need to make up some decent scrapers. My cousin who has an auto shop uses a rod with a wooden handel. hole drilled and tapped on end that holds a square carboloy insert that is used in machine work. I like the idea of the aluminum scraper. Thanks for the help.
WVJim
11-08-2005 20:59:33
 Re: Gasket remover in reply to John/Pa, 11-07-2005 02:51:27
Piece of copper tubing flattened and sharpened works good too.
