Hi Glenn, To me the first thing that is important is having a truck with floating axle so there bearings don't get pulled off the axle like they can with the 1/2ton and lighter vehicles. From there then it's no overloading the rear axle tires for there rating. Most larger axles can take load weight equal too the tire ratings with a good safety margin. The Dana60 can be built to a 20k# axle spec with the correct componets. I've always used my trailer brakes first before I use tow vehicle(TV) brakes, just the way that I was taught. I have my F350 set up to where my brake controller is mounted on my gear shift as that way I have one finger touch control of my trailer brakes. I always use my gears to control my load weight. Even with the PSD and NO exhaust brake, I dodn't have a problem with using engine compression other than the engine needs to run at 3200rpm to apply compression breaking. If I have to apply my brakes more than 3 times while descending a long grade then I'm in too high of a gear and need to down shift into a lower gear. My new GN flatbed came with Dexter forward self adjusting brakes. Something that all Dexter electric brake axles have since 2004 according to the trailer mfg. Even as heavy as I was loaded on my last trip, 31kGCW, I had no problem stopping my rig if needed but that was on new trailer brakes. I doubt that I'll run 31kGCW in the future as this is just too much weight for a F350 DRW and is not cost effective however I didn't see a problem at 26kGCW other than projected high maintance costs. As it is I usually get 100k miles plus out of my TV brakes. To me, it's cost effective to eat up trailer brakes as there cheaper to replace than TV brakes. T_Bone
