Tool Talk Discussion Forum
ford 2110 (yellow)
Dan in VT
11-04-2005 18:20:04
I have a ford 2110 (yellow body, wide stance); I think it
is a mid 80"s. anyway, while brush-hogging a neighbors field, she started spewing what I believe is hydraulic oil out of what I believe is a hydraulic pump that sits above the transmission just behind the steering wheel and beneath the aircleaner. I do not have a manual, otherwise I"d know these things. The unit in question has two tubes coming out that run down to the back of the tractor, driver R. The oil is spewing from one of these tubes as it exits the pump. Any idea what this is? What is wrong? How to fix? And, what model this is?
Thanks.
JoeK
11-04-2005 19:13:06
 Re: ford 2110 (yellow) in reply to Dan in VT, 11-04-2005 18:20:04
If you have not,suggest you try the Ford Forum on this site.Yellow paint usually designates an Industrial vs Ag model.Either way the Ford gang should know whatcha mean and how ta fix it.
