Tool Talk Discussion Forum
hydraulic floor jack
Sidney
11-04-2005 10:44:43
How do you check the oil and/or add oil to a Craftsman 2-3 ton floor jack. It won't lift but a few inches.
msb
11-04-2005 19:25:56
 Re: hydraulic floor jack in reply to Sidney, 11-04-2005 10:44:43
If it doesn't show where it has leaked then it is probably filled with air.Try this;Close the valve and pump the jack up as high as it will go.Then invert the jack and let it set this way for a few seconds.With the jack still upside down,open the valve and push the ram back into the bottle.Do this until it will raise all the way when pumped in the upright position.I bet it will fix your "leaky" jack.Bet you a dollar to a Crispy Creme donut?
RustyFarmall
11-04-2005 21:20:57
 Re: hydraulic floor jack in reply to msb, 11-04-2005 19:25:56
That trick works very well with a bottle jack. Kinda hard to do with a floor jack.
drw
11-04-2005 18:43:07
There is a rubber filler plug on the round part (this is the oil reservoir) of the power unit. Carefully remove & fill will hydraulic jack oil to within about 1/4" or so from the top. If you get too much in it won't go all the way up either. Do not remove either slotted plug on the top of the square part on either side of the release gear. One is the lifting valves, the other is a calibrated relief valve. Carefully work the rubber plug back in when done.
Vern-MI
11-04-2005 12:03:55
Model Number?
Either a screw on the main body or a plug in the barrel of the head.
