Tool Talk Discussion Forum
Burning newspaper in wood stove ??
Bryan in Iowa
11-02-2005 09:08:52
Is there a good way to make logs or something out of newspaper? I have lots of newspaper ,,use it for starting fire,,but is there some way to roll it to burn ???
Coldiron
11-04-2005 07:22:53
 Toxic Ink in reply to Bryan in Iowa , 11-02-2005 09:08:52
A few years ago there was a notice not to burn the papers with yellow coloring. The yellow ink was reported as being toxic and a real health hazard. Might want to leave yellow out of your fires, just in case. They may have changed the formula but why take a chance ?
RickL
11-04-2005 05:57:22
 Re: Burning newspaper in wood stove ?? in reply to Bryan in Iowa , 11-02-2005 09:08:52
have one of those paper rollers that is pictured in one of your responses. Would sell it to you if interest and if I can find where its at around here
Ryan - WI
11-02-2005 17:49:46
Rolling them tight within a mixture of water and laundry detergent then letting them dry works too.
Bus Driver
11-02-2005 16:06:38
The glossy magazines mentioned are called Coated Paper. The paper is actually coated with white kaolin- a clay. One of the most fire resistant materials. That is why coated papers are too expensive to recycle.
T_Bone
11-02-2005 14:45:01
Hi Bryan,
My SIL used to heat her house in Denver with rolled up news paper hand tight, rubber band both ends, then soak in a tub of water then sun dry. Looked like they burnt like logs and she said they gave off good heat. I never tried them myself.
I did hit Office Depot when they had a sale on paper shreaders for $10. I bought 4 and use them to shread news paper and magizines and mix the colored paper with good burn paper for starting my wood stove. Best thing since sliced bread.
T_Bone
buickanddeere
11-02-2005 12:30:08
News paper will burn but glossy magazines will just smother the fire with huge ash flakes.
Robert in W. Mi.
11-03-2005 07:57:44
 Re: Burning newspaper in wood stove ?? in reply to buickanddeere, 11-02-2005 12:30:08
I put all my glossys in a 5 gallon bucket "on end". Then i dump about a gallon or more of used motor oil on top of them. After a month or so, they burn real nice... :>)
I add to one side of the bucket, and take away from the other side as needed and also add oil as needed as they soak it up.
Robert
Galen
11-02-2005 10:42:13
Old boy down the road used to shred them, make a pulp out of them, mix with saw dust from his wood shop, and dump the whole mess into a round duct pipe. He'd let them dry (1-2 months) and they would burn for ever.
BBx
11-02-2005 09:39:06
Check the link below.
BBx
11-02-2005 09:41:43
 Re: Burning newspaper in wood stove ?? in reply to BBx, 11-02-2005 09:39:06
Or this one. A little cheaper.
old
11-02-2005 09:11:24
They usto make a thing that would roll it real tight and then you would dip it in wax. I haven't seen or heard of one in probably 20 years though.
Stickler
11-04-2005 16:13:32
 Re: Burning newspaper in wood stove ?? in reply to old, 11-02-2005 09:11:24
i still have 2 of those from a long time ago. And a box of the long twist ties they used to hold them together.
