Tool Talk Discussion Forum
F150 Door Hinges
Scott.ID
10-31-2005 15:31:34
Howdy all,
My '96 F150 needs new hinges (or pins) on the drivers side door.
called the local Ford garage, around $100.00 PER HINGE! anybody ever replaced just the pins and bushings, of know of a Reasonable place to get parts?
Thanks!
Scott
Thanks All!
11-05-2005 16:50:26
 Re: F150 Door Hinges in reply to Scott.ID, 10-31-2005 15:31:34
I checked with Napa and bought new pins and bushings for $12.00. I figure I can rig something up with a cherry picker to hold them up while I'm working on it.
$300.00 at the ford garage. cripes! I can buy a new cherrypicker and still be ahead!
Scott
onefarmer
11-01-2005 12:23:40
I use the link below to check for parts and prices. Makes a great starting point to see what is availible and for how much. Less travel and sticker shock that way.
Pappy
10-31-2005 22:50:56
I saw hinge pin/bushing kits at O'Reilly Auto Parts store. Several kits on hand to fit many vehicles.
Lefty
10-31-2005 21:52:37
Check your local NAPA,they should have pin and bushing kits on hand.1 kit per door...Can't remember but seems to me they were under $10ea.
John Niolon
10-31-2005 16:43:08
Scott,
I'm building a '53 street truck... I found oversized hinge pins... drilled the hinges and drove them in... there are several aftermarket outfits that will sell them I"m sure...
check out www.ford-trucks.com and look in the late model forums ...ask your same question and I'll bet you get covered up with suggestions... we got a great bunch of guys there..
you can try here also
Link
john
jimlll
10-31-2005 16:17:17
The doors on my 91 F250 were sagging, with an air gap on the upper front of the doors, I loosend the hinges, readjust, and replaced the striker pins as the plastic sleeves were missing. This completely took care of gaps. Hope this may help.
