Tool Talk Discussion Forum
Rebuilding Distributers
Don Ward
10-31-2005 07:01:07
I read a few years back about a fellow or company that would rebuild an old tractor distributor to give the engine more power. The weights are currently designed more for economy then peak horsepower. Does anyone know whom does this sort of work now? I tried searching many sites but found nothing. Thought I read it here a couple years back. Thanks for any help.
Big Mike(Mi.)
11-04-2005 18:32:55
 Re: Rebuilding Distributers in reply to Don Ward, 10-31-2005 07:01:07
Don:call Denny's carb shop-937-368-2304. He has an ad in the Sept./Oct. 2005 issue of Antique Power magazine(page 85) sya's he build fuel and ignition for farm,show and pulling tractors.
Don't know anything more just saw the ad.
Hope it helps!!
Mike.
Bob
10-31-2005 08:09:07
You posted "The weights are currently designed more for economy then peak horsepower."
I don't think that is a true statement with the typical older gasoline powered tractor.
Lots of advance, up to just before the point where it "pings" under load, will give both max HP and max fuel economy, with the added bonus of reduced exhaust gas temperatures and cooling system "load".
However, cars and trucks of the early emissions era are another matter, because the factory advance curve was set up for reduced emissions, at the COST of fuel efficiency, and increased cooling system load.
