Tool Talk Discussion Forum
PTO Powered Generator
Logan in S.E. T
10-29-2005 21:58:28
Looking for information on subject. Since living through 15 mostly HOT days after Hurricane Rita without electricity, I am interested in aquiring one of these. I have only the slightest knowledge that such a thing exists. How many KW's can/do they produce? What are some of the better brands? What do you have to be careful about when buying a used one? Where can such a thing be found? In my part of the country they are unheard of as far as I know. Thanks for any information that is forthcoming. I have a MF 283 tractor to run it with. Thanks, Logan
rad
11-03-2005 10:44:21
 Re: PTO Powered Generator in reply to Logan in S.E. Texas, 10-29-2005 21:58:28
I considered a PTO driven generator, but rejected it because was too hard for my other half to hook up if the power fails while I am traveling. Ended up buying a brand new 10KW Miller Bobcat 250 gas powered welder/generator for under $3000. Now I have a portable welder (well if you call 700lbs all gassed up portable) and an emergency generator that will power the entire house.
Next step is to add a whole house transfer switch (a mere $400 from Graingers) so I can safely feed the house and not fry linemen.
Leland
10-30-2005 18:23:38
Check out northern tool they have some low HP models and you may get free shipping if they are in the mood .
Logan in S.E. Texas
10-30-2005 16:59:48
Thanks guys for the replys. I found both of those places plus some and also on E-bay.
ronnie269
10-30-2005 16:32:32
check steadypower.com
buickanddeere
10-30-2005 07:48:49
Generator Joe. Nobody ever bought a too large generator.
Logan in S.E. Texas
10-29-2005 23:54:11
Never mind folks. I went "surfing on the 'Net" and found more information than I could use.
Thanks anyway and sorry for bothering anybody.
Logan
