Tool Talk Discussion Forum
Oil furnace question
gcs
10-29-2005 10:09:53
Have an oil fired, hot water baseboard system at home.
Was wondering if anyone can tell me what the most efficent temperture to set the aquastat?
for instance, water temp.,and ease of heating, vs. oil usage.
Lowest temps "here" would be a rare zero degrees, avg probably mid to high twenties, once winter sets in.
House is well insulated.
Thanks, George
gcs
10-29-2005 12:14:42
 Re: Oil furnace question in reply to gcs, 10-29-2005 10:09:53
Bob, thanks for the links,
The boiler will keep the temp. between the high and low limits all the time, whether the circulator is running or not.
I usually lower the limits to minimum during the summer, and raise the aquastat gradually as it gets colder, I think it's set for 160 right now, when it gets really cold I may bump it up to 180 .When I moved here, it was set to a little over 200, which seemed way high.
I guess I'm keeping it about right, just didn't know what was considered "right" :)
Bob
10-29-2005 10:52:41
Simple answer is set it to a lower temp in mild weather, in COLD weather, set to a higher temperature that is still adequate to heat the building on the coldest, windiest night.
You can get an aquastat that has 2 heat-sensitive bulbs... One goes outside, and one senses the boiler water temperature. These units track the outside temperature, and raise and lower the boiler water temperature as the outside temperature changes. They can be a real fuel saver.
How are the controls on your boiler wired... does it always stay at a fixed temperature as long as it's turned on, or does it only fire as long as the circulator pump(s) is running, and only heat up to full limit temperature if the pump(s) stay on long enough?
Here's a link to an energy conservation site that gives some suggested temperatures... see "Aquastats", the last paragraph on the page.
Link
