Tool Talk Discussion Forum
Chainsaw adjustment
A owner
10-29-2005 05:39:54
How do you set the adjustment (hi/lo) on a poulan 4400 chainsaw. I couldn't get it to start, removed carb., cleaned, turned adjust. screws into their previous position. Saw starts and idles, when you give gas, it stalls out.
dhilbert
10-31-2005 05:22:30
 Re: Chainsaw adjustment in reply to A owner, 10-29-2005 05:39:54
when the saw stalls like that you need to give the low setting more gas, it needs to run a little richer, try turning the low out 1/4 turn at a time and try until it clears up. good luck
JT
10-29-2005 08:33:38
Start with both screws out 1 1/2-2 turns
