Instructions will probably eplain much better, but for the most part, a multimeter is a multimeter. Will probably have an AC scale, which you won't use on or around a tractor or vehical, since is DC but will come in handy around the house for measuring AC. Your DC scales, like your AC scales may come in multipliers (10 or below, 300 or below, 600 or below, etc.), so going to need to find your scale (the first one greater than your value of 6 or 12VDC) and go across your terminals with the probes. DC's polarized, AC's not. So if put your probes across the battery terminals for instance, and the meter tries to go negative, reverse the probes and get a proper reading. There will undoubtedly be a scale for measuring resistance (measured in ohms) that will probably be marked Rx1, Rx10, Rx100, etc - great for finding shorts, reading components, etc. To test it, turn the dial to Rx? and touch the probes together, then adjust for zero so is referenced properly for that function when you begin. Don't read across a voltage in any "R" position, or can/will pop the internal fuse, but can read a leg that's hot without blowing the fuse. What I mean, don't read across the battery terminals in the "R" position, but can read from one battery terminal to the other end of the cable connected to that terminal while the cable's hot. When you look at your meter, will have different scales marked in different colors, marked to coincide with the different positions of the dial of the meter. The manual will do a better job than I can or did, but those are the basics. Always shut the meter off when you are done, there's an internal battery used for the Ohm scale (resistance) and will go dead powering the meter, much like leaving a transister radio turned on. Be careful when probing around so you don't hit the wrong thing, short the meter, short a vehical component, melt the probe leads, etc. Excellent tool you got yourself there. Learn how to use it, you'll love it. One of the most basic and important when dealing with electricity. Good luck, enjoy it, use it in good health. Don't get discouraged. If I can do it, you can do it better with practice. Next tool? Pick yourself up an O-scope. Won't do resistance readings, but will do everything else, and a world more. Mark
