Tool Talk Discussion Forum
Sears compressor ID and question
Jeff Passmore
10-27-2005 09:54:46
Hi,
In the "Help Identify" page I have posted pictures of an old Sears compressor. I need to know the pump type and have a question about the check vavle.
Where the valve screws into the manifold (hope these are the correct terms) the threads appear to be straight not pipe, is this normal? If so, how do I keep the joint from leaking air?
Thank you for your help.
Charles (in GA)
10-28-2005 06:00:49
 Re: Sears compressor ID and question in reply to Jeff Passmore, 10-27-2005 09:54:46
I have a 106.153542 its 100 psi max, 6.4 CFM @ 40 psi, 12 gal tank, 1 hp. Doesn't even have a belt guard on it, its so old, that was an accessory you could buy back then (I bought it new when I was about 16 or so). It has a 120/240 motor. I've kept it 120 for portability and the only mod I've done to it is to add a handy box and on/off switch to it. Still looks like new. Come to think of it, that is Speedair green, isn't it. But then again, the Sears floor jack of the same vintage (was) the same green as the compressor.
Doesn't get used much nowdays, I ocassionally run it just to keep it running, always leave the tank with 100 psi in it, they last better that way.
Charles
XXXRogerXXX
10-27-2005 13:52:36
It's an old SpeedAire compressor. The threads should be NPT, and require just thread dope or tape.
John in MA
10-27-2005 15:16:36
 Re: Sears compressor ID and question in reply to XXXRogerXXX, 10-27-2005 13:52:36
Isn't Speedaire just Grainger's store brand? That one in the photo looks like an old CH. They made a lot of stuff for Sears back in the green phase in the '60s. The model number on the tank would say for sure.
jeffpassmore
10-27-2005 15:31:43
 Re: Sears compressor ID and question in reply to John in MA, 10-27-2005 15:16:36
Hey John,
The model #106.153782, it is on the Sears parts site but I didn't see any reference to maker.
The old CH Sears I have seen have a straight finned head not the radial. Not a big deal just wondering.
Thanks for your input.
John in MA
10-27-2005 18:44:04
 Re: Sears compressor ID and question in reply to jeffpassmore, 10-27-2005 15:31:43
From that number it could be Tate, Whirlpool, or Campbell Hausfeld. Seeing as only one of them makes air compressors, I'd guess it was a CH. I used to have one a while back. Still use the tank with my homemade compressor since the original lunched.
jeffpassmore
10-27-2005 15:03:09
Hi Roger,
Thanks for the info. I did some intense looking this afternoon and found an exploaded view on Sears Parts .com they call for a gasket under the check valve. This makes sense to me as the threads sure seem straight or standard and do not begin to tighten up at all as the check valve is screwed in.
The pump runs fine, just interested in terms of parts in case i need to rebuild it at some point. An old boy on another site said Quincy made those pumps for Sears that far back (1970's)
Thanks again
Larry in TN
10-27-2005 17:02:34
 Re: Sears compressor ID and question in reply to jeffpassmore, 10-27-2005 15:03:09
It's a Speedaire. Sears had several compressors modeled on that pump. 106.174541&542===1hp. 106.173781&785===2hp. 106.171880===3hp. Parts on all but the 106.171880 appear to interchange. The check valve uses a gasket and tends to leak. Replacement check valves tend to be slightly longer than original and bottom out in manifold before becoming air-tight. The valve is useally ruined as a result if tightened further.
jeffpassmore
10-27-2005 17:08:36
 Thanks Larry in reply to Larry in TN, 10-27-2005 17:02:34
Thanks
