Tool Talk Discussion Forum
clutch drive disk stuck
joel rand
10-25-2005 08:17:09
I"m trying to pull the fixed clutch drive disk off the JD 720 Diesel. Heat, pounding, hydraulic puller, 4 ton portapower puller, nothing has made it budge. Do I need to start thinking about torching it off, I"d really like to not ruin the crankshaft. What is the biggest, strongest puller you can buy?
JMS/MN
10-26-2005 11:35:46
 Re: clutch drive disk stuck in reply to joel rand, 10-25-2005 08:17:09
Heat and candle wax.
Mike M
10-25-2005 09:14:35
Wow ! I can't say that I've had any that tight.Does your driver have the 2 threaded holes in it ? If so screw some bolts in there tighten them up and if it still won't go try some heat while it's still under tension.You have to use a regular torch outfit as if you just try a burnsamatic it won't get hot enough fast enough. Don't take this the wrong way,but you did take the bolt out of the crank center didn't you ?
