I think a 1/2 ton is a little short when pulling 9,000#'s - I'd rate their towing capacity at 5,000# to 8,000#. I think the 3/4 ton pickup would be better for 9,000#'s as it has larger a capacity frame and brakes but would go with a 1 ton for the full 13,000# capacity. The deciding factor is your specific vehicles towing capacity. Their are a lot of options to increase towing capacity like a dual wheels. Check what the manufacturer rates your tow vehicle at. I hope you have electric brakes - Stopping is what would worry me most. 9,000#'s will push even a 1 ton pickup quite a distance. Be careful You also need 4 sets of chains and binders for that much weight that are clearly stamped. Your required to secure your tractor at 4 points. Be careful an old G70 chain rated at 5,000# + with out the markings is considered standard chain 2,000# or 3,000# when your stopped for inspection. They will most likely impound your vehicle for this. Licenses are a little confusing. For a trailer over 9,999#'s the Fed DOT wants a CDL with a trailer endorsment for the registered weight - in your case 13,000 #'s. If you not using it for hire NYS (for example) says your combined truck and bumper pull trailer have to be under 26,000#'s. Not sure if your legal or not and even if your are in NYS you might not be in NJ, CT, PA or DE. Good luck be safe
